Old 10-15-2009, 09:06 AM   #21 (permalink)
POW/MIA'S NOT FORGOTTEN
Drive: 09 Red/Blk/Blk Passion
Originally Posted by jetfuel View Post
...allowing hot air to get under it...
jetfuel...BTDTFT
And NOBODY knows more about HOT AIR than jetfuel
Old 10-15-2009, 04:55 PM   #22 (permalink)
Originally Posted by Duckhunter View Post
You made me look at mine. There are some studs mounted back there and the padding is held up by plastic washer type fasteners that thread to the studs. I see at least three back in there.
True. ... a few here and there, particularly up at the carpet/firewall location. (--check the deadpedal area, for example...you might also examine the pasenger footrest area--I can't recall all of the specific locales).
Anyway, several fasteners on my '08 (ordered '07) were not "snug". Simply turning them by hand will tighten then up. Avoid adhesives for this application, unless absolutely necessary.
MHLO, of course...
EdwardDennis is offline   Reply With Quote
Old 10-23-2009, 06:22 AM   #23 (permalink)
Commander Cody's Avatar
Drive: Subie
Engine Toupee now fixed
Went with Jetfuel's idea of some Loctite Red RTV gasket stuff and that did the job. After frequent runs in the car and then inspection (the insulation over the rear of the engine - not the removeable lid) it is holding to the metal. Spread a good bunch of it on your finger and smear it all over the metal to which the insulation is to be attached. Now the important part. You've got to have some metal clips much like you would use to hold paper together or clothespins or anything that will hold the insulation up against the metal. I ended up stuffing whatever I could find up against everything to hold it in place for 24 hours. And that did it.
Commander Cody is offline   Reply With Quote
Old 10-23-2009, 07:21 AM   #24 (permalink)
Thanks for the Memories
Originally Posted by Commander Cody View Post
Concerns of Cdr. Cody in RE: engine insulation
I would think as a good "Commander", your FIRST concern would be to find your airmen on the Lost Planet before asking about added insulation for your smart........
Old 10-23-2009, 07:38 AM   #25 (permalink)
Well, there IS that family in Colorado.................
Old 10-25-2009, 06:33 AM   #26 (permalink)
Drive: Subie
True Big Panda true. But take note. I didn't add insulation. I only attempted to stop what I had from hanging loose over the rear of the engine.
Previously I mentioned that it had actually fallen over the alternator whose belt then made lunch meat of it.
Old 10-25-2009, 08:27 AM   #27 (permalink)
i used small velcro tabs that i stuck to the metal part aboue the cover material... and got some eye hooks like you use to secure your pants like on slacks and such from a sewing supply place .. attached the velcro tabs to the hooks then hooked the edge of the engine cover material. seems to be working very well so far.
foyfarlow is offline   Reply With Quote
Old 10-25-2009, 09:18 AM   #28 (permalink)
I stand corrected.....thanks Commander.
btw, I loved "Hot Rod Lincoln" so much that I literally wore out my "Lost in the Ozone" 8-Track Tape.
Old 10-25-2009, 02:00 PM   #29 (permalink)
BigGoofyGuy
BigWarpGuy's Avatar
Drive: Smart Fortwo Pure
Halloween costume
Halloween costume idea?
Old 10-26-2009, 01:59 AM   #30 (permalink)
NeWave's Avatar
Drive: 09 Passion Coupe
MHLO, of course...
Before I read this thread I noted mine were quite loose, not even not snug. Might want to keep that in check, everyone....
Loose engine compartment insulation. SLIVERS Smart Car General Discussion 1 04-15-2009 06:08 PM
Smart battery died while in storage / tire flat spot concerns. iMacDaddy Smart Car General Discussion 13 02-23-2009 09:07 AM
Sun Shade Mods - Concerns? The GMan Smart Car General Discussion 2 07-04-2008 11:46 AM
Hot engine stilamama Smart Car Operation and Maintenance 7 05-03-2008 06:09 PM
Love the Smart Car, but have several concerns... mikesnav Smart Car General Discussion 11 08-17-2007 04:34 PM
