Coolant Change on '09-451 - Smart Car Forums
post #1 of 32 (permalink) Old 10-18-2012, 12:26 PM Thread Starter
Schlauwagen's Avatar
Quoted: 2 Post(s)
Hi Smarties...
Only 2.5 weeks old here . Am approaching 40,000 miles on my "new to me" 2009 Passion and am ready to tackle the 40K maintenance. Am pretty handy and well versed in things mechanical; however don't have a shop manual; cannot find one! The only major service now is coolant change besides the oil/filter change.
Planning to do a coolant/flush, etc. So from where do you drain it from(radiator petcock?) and to where do you fill the new coolant(expansion bowl?) and at what glycol/water % mix? Then you gotta "burp" her..right.?.IS there a procedure for the burping??
Thank you..
Cheers...
Schlauwagen is offline
post #2 of 32 (permalink) Old 10-18-2012, 12:33 PM
Quoted: 68 Post(s)
jwight is online now
post #3 of 32 (permalink) Old 10-18-2012, 12:36 PM
183K+ miles
WhiteNBlack08's Avatar
Quoted: 356 Post(s)
Here you go, official smart proceedure:
New engine problem: can't flush air from it
WhiteNBlack08 is offline
post #4 of 32 (permalink) Old 10-18-2012, 12:39 PM
Quoted: 68 Post(s)
Deja vu all over again!
post #5 of 32 (permalink) Old 10-18-2012, 12:46 PM
183K+ miles
Quoted: 356 Post(s)
Yep, you're faster than I am. You beat me to it.
post #6 of 32 (permalink) Old 10-18-2012, 01:13 PM
Quoted: 84 Post(s)
chieftmc is offline
post #7 of 32 (permalink) Old 10-18-2012, 02:37 PM Thread Starter
Quoted: 2 Post(s)
As always...Thank you... jwight...and the rest who wanted to chime in but our Bohemian Moderator was zu schnell, wasn't he? .
Curious !?..we can use the block drain procedure Evilution uses ? instead of the hose "burp", right IF we have that Allen drain plug. Haven't looked for it yet...engine too hot now...
Cheers...
post #8 of 32 (permalink) Old 10-24-2012, 10:51 AM Thread Starter
Quoted: 2 Post(s)
Coolant change/flush..AGAIN!!
Hi All..
Another coolant change subject, ahem..!..BUT..after going through all the motions here regarding coolants, Evilution, WIS, etc...it seem that the coolant after removing the expansion cap can be totally emptied by just opening the block screw which is lower than the lower radiator hose! This will drain the ENTIRE coolant entirely?? Then one doesn't have to mess with accessing the lower radiator hose. OF course will one have to "burp" at the end of the coolant change at the block head!
What say you ?
cheers...
post #9 of 32 (permalink) Old 10-24-2012, 11:58 AM
Quoted: 84 Post(s)
Originally Posted by Schlauwagen View Post
Hi All..
What say you ?
cheers...
Should work
I pulled to lower radiator hose
chieftmc is offline
post #10 of 32 (permalink) Old 10-24-2012, 05:28 PM
SmartDigger's Avatar
Quoted: 176 Post(s)
could you clamp off the lower hose and drain and refill the radiator to do a change out.
SmartDigger is offline
Human Verification
331
How critical is O-ring change while doing oil change? joeshark smart Operation and Maintenance 9 05-13-2012 07:59 AM
40K on the Odometer, time to change the coolant? forestacademy smart Operation and Maintenance 10 07-01-2010 06:57 AM
Smart 451 Flat Belt Change joseluiscarrillotomas smart Operation and Maintenance 5 05-22-2010 06:47 AM
451 miles on my most recent tank! 451 in a 451! unicycle smart General Discussion 1 04-09-2010 08:45 PM
Need coolant help sksmn14 smart General Discussion 4 07-01-2009 09:40 AM
