Curt Hitch on a Brabus? - Smart Car Forums
post #1 of 5 (permalink) Old 04-26-2014, 08:25 AM Thread Starter
BB Benz's Avatar
Quoted: 226 Post(s)
I installed a Curt receiver hitch on my Brabus yesterday. The instructions exclude the Brabus as an exception to compatibility. This may apply to turbo Brabus models, not the U.S. versions without them. They don't say.
The only reason that I can see for excluding a North American Brabus (which is basically a passion with window dressing and a center outlet exhaust) is that the hitch ball extension might become heated from the exhaust exiting the twin pipes and possibly pose a burn hazard.
If I find that the bike rack I plan to use (Swagman) is heated from the exhaust, I might wrap the upright with a.c. pipe insulation and wrap the outside of it with black duct tape to protect the closed cell foam from the exhaust.
To complete the project I will have to come up with some form of bracing from the towbolt holes adapter bolts that I have already acquired, to prevent sway and provide relief support to take some of the strain off the hitch.
A tip of the hat and Kudos to JKJAHobbs for sharing the knowledge regarding an alternate way of installation that does NOT include grinding out large holes in the frame thru which to insert bolts and large washers per the included instructions. Grinding such a large hole is not an easy task, times two.
Simply removing the 3 inner bumper attaching screws on each side allows the bumper to be slid far enough side to side to uncover the open end of the frame. It is then very easy to fish the bolt and anti-rotation washer or spacer into place with the supplied fish wire.
When fishing the bolts thru, it is only necessary to thread the bolt into the fish wire a few turns or it will not want to unscrew from the fishwire. Thankfully they supply two fishwires.
Access to the bumper screws is much easier if you remove the rear wheels.
Also, on the Brabus rear skirt the two screws that are normally exposed on the rear skirts of pures and passions are covered by a snap in matching plastic cover. The tabs that snap in are accessible underneath so that the plastic shiny finish is not damaged from prying.
One hole still must be drilled but it is only a half inch hole instead of the one inch hole with additional widening by grinding that I just did not want to do to the frame of my car.
BB Benz is offline
post #2 of 5 (permalink) Old 04-26-2014, 10:10 AM
OTD3 lifetime Member
jsenka's Avatar
Quoted: 93 Post(s)
You folks with hitches on your Brabus models will have to get used to having your balls roasted!
At the last Dells gathering, someone with a center exhaust had a spare tire mounted in front (or behind, as the case may be) of the outlet and the tire was burned and blistered pretty bad by the exhaust stream. I'm not sure your A/C insulation and black tape will suffice. But, YMMV.
Maybe some muffler wrap?
jsenka is offline
The Following User Says Thank You to jsenka For This Useful Post:
BB Benz (05-01-2014)
post #3 of 5 (permalink) Old 04-26-2014, 11:57 AM
Quoted: 481 Post(s)
Removing the inner bumper bolts worked for me! made the whole thing much easier to install on my Pure!!
jimvw57 is online now
post #4 of 5 (permalink) Old 05-13-2014, 07:46 AM
what year was your Brabus? I have a 2013 and called Curt and they said it would not fit. My exhaust is a little to the right side of center looking from the rear and points a little down.
thanks,
blaise
Motorboat is offline
post #5 of 5 (permalink) Old 05-13-2014, 10:02 PM Thread Starter
BB Benz's Avatar
Quoted: 226 Post(s)
Mine is an 09.
The only difference that I know of is the muffler with the center outlet exhaust. The US 451 is basically a passion with the center outlet exhaust and everything else is decor.
BB Benz is offline
Human Verification
331
HOW-TO: Step by Step Curt/Uhaul Hitch Install (LOT OF PICS!)l Kermit smart Towing 48 12-09-2015 10:44 PM
Curt trailer receiver hitch diverpilotmike Archive/obsolete (?) threads 3 03-23-2014 10:15 PM
Curt Hitch ??? sheureka smart Towing 34 06-26-2010 08:44 AM
For Sale: New in Box Curt Hitch From eTrailer Kent Smith Archive/obsolete (?) threads 0 11-30-2009 11:30 AM
Smart car Class 1 Hitch by Curt chinaski Archive/obsolete (?) threads 0 03-09-2009 09:29 AM
