Disabling ESP? - Page 6 - Smart Car of America Forums : Smart Car Forum
Old 10-30-2009, 10:45 AM   #51 (permalink)
Owner for 3.8 years
Kermit's Avatar
Originally Posted by BigWarpGuy View Post
The 'triangle with the exclamation point in it' is lit. Could this indicate that the fuse needs replacing? The manual indicates this light is for the ESP and that it goes on when it is off or not working. I have to look where the fuses are.
BWG, you've got problems if it is turning on this often. Like I said, I have a similar problem but it only comes on and stays on for VERY specific conditions and has only done so a few times.
Check that fuse if it is staying lit even after a reboot (turn car on and off). I suggest a trip to the dealer and I hope you're within warranty still. Good Luck.
Old 10-30-2009, 11:08 AM   #52 (permalink)
BigGoofyGuy
BigWarpGuy's Avatar
not yet two years old
I bought my car in March 2008. It is not quite two years old and the warranty is for two years (?). It should be - hopefully - under warranty. I will contact the service center at Smat Center Edison. Thank you for the tip.
At first it would not come on in the morning after I it was lit. Now it seems to be on all the time.
Old 09-10-2010, 08:21 AM   #53 (permalink)
ckman9's Avatar
ckman9 is offline   Reply With Quote
Old 09-10-2010, 09:28 AM   #54 (permalink)
sato7's Avatar
ckman9, did you press both buttons or just the left one... and how do you return to normal mode?
Old 09-10-2010, 10:19 AM   #55 (permalink)
I would hope it would return to normal after it is turned back off.
My Car is gone for the weekend so I can't try that trick. Got to wonder if that is possible here in the US, if it is it might be just the thing if your stuck in a snow bank and need to try something else
Old 09-10-2010, 10:27 AM   #56 (permalink)
CT Chapter President
smartcar111's Avatar
I might go try that, but if it doesn't return to normal mode after turning it off, no thanks.
smartcar111 is offline   Reply With Quote
Old 09-10-2010, 10:37 AM   #57 (permalink)
I'LL BE DAMNED! IT WORKS!
Video going up soon.
Old 09-10-2010, 11:11 AM   #58 (permalink)
Old 09-10-2010, 11:52 AM   #59 (permalink)
Neonspinnazz's Avatar
I hate this darned classroom! YouTube is blocked!
I'll be home in 2.5 hours...
In the meantime, I'm not happy...I cannot find my telephone script for my notes...
Old 09-10-2010, 11:58 AM   #60 (permalink)
To the XCAPEPOD!
rfernatt's Avatar
Originally Posted by smartcar111 View Post
IT WORKS!
Nice vid - big hands will be helpful! Not to be picky, but since this is undocumented and all we have is a flashing light, how do we know that it works in actuality? Can you spin the tires in wet grass? Does ABS definitely not work? Is there a way to find out? Are there unintended negative side affects other than missing TCS/ABS?
esp, factory options, traction control
