But c'mon people, it's time to join the late 20th century.
When technology catches up with what I want as a driver,I'll be glad to move to an automatic or other variant. Yes, I know that some high tech race cars are using some variation or another with great success, but I can't afford $50k for the tranny alone.
I rarely get caught in a jam. I've driven clutch for the last 20 years or so and prefer having more control in shifting. It's more economical, easier on brakes and just more fun IMHO.
I drive Dallas traffic all of the time with my manual transmission. I have had a CVT as well and went back to a manual. I worry that the clutch may burn out in these cars being that they are automated manuals and will be trying to creep forward like an automatic. Being that they have been in use in London, I hope that all of the bugs they may have had will have been worked out.
I'm no motorhead but when sitting you have the option to slip the tranny into neutral rather than idling in the engaged position. A more tech oriented guy could tell you which is better for the transmission.
BTW, Dave, I'm stealing that little Smarty gif you have. That is too cool.
Reason: adding....
I don't think they built in a problem that when you are stopped with the car in drive would cause any problems.
When I was testing driving and stopped the car at a light. I just put on the brake, it didn't stall because I forgot to push in on the "clutch" like a manual would. I think the creep happens with a small push on the gas.
What I really want is a dual clutch version of an automated manual transmission. This is the "next generation" automated manual, and may or may not end up on the smart at some point in the future (some VWs and Audis already have it).
The US auto industry is quietly investing big bucks in this technology, as it has the promise of completely replacing the current torque converter based automatics with big improvements in efficiency (equals better gas mileage equals a prayer of meeting the new CAFE standards).
The best single clutch automated manuals can perform an upshift in about 80ms; the dual clutch version cuts that to 8ms. I can live with that!
Here's a good technical article about the technology (even has cool cutaways):
given the creep at idle with the auto manual (grinding and sanding the plate surface off),
how does one prevent early wear out of the clutch plate?
to replace the clutch plate, is a lot of work for a do it your-selfer (or at least it is in a standard 5 sp with clutch pedal. likely equally as difficult, maybe even more difficult, with the auto manual?).
which also means quite a bill to have it done.
question:
what practices can 1) lengthen the life of this auto manual? and 2) get the most mpg efficiency from of the auto manual?
can you shift it to the 'N', neutral postion, when idling, to take pressure off the clutch, and reduce its wear?
or does shifting back and forth from drive to neutral and back to drive, also cause excessive wear?
when coasting, can you put it in neutral, to save gas, and reduce clutch plate wear? or does that 'in and out' action, cause extra wear somehow?
anyone have tips, to boost the life of the clutch plate with auto manual?
is this why the company is worried about not giving a longer than 2 year warranty? they know that clutch plate will need replacing, often, and soon?
uggg.
--00000000000000000000--
late edit added:
questions after reading the above sited, double clutch transmission (dct) 'how stuff works' page:
is the smart a dry or wet clutch?
if the dct is so 'lighting fast' in its shifting (according the article description), why is the smarts shifting so 'jackass asleep slow'?
and what are the differences, of what smart has, and what the race cars use, to attain this continuous power applied shifting? (again, when it 'seems' the smart hesitates, between shifts, and doesn't 'feel' like the smart is applying continuous power during shifts? - or at least, that is my recollection, impression, from long ago july 07 test drives. - )
