Electric Smart Specs - Smart Car of America Forums : Smart Car Forum
Old 07-07-2008, 10:17 AM   #1 (permalink)
kwagar's Avatar
World premiere at the British International Motor Show:
smart fortwo with electric drive
to start as a pilot project in Great Britain
Böblingen – From November 2006 the smart fortwo will also be available with electric drive. As part of a pilot project, in Great Britain around 100 smart fortwo evs will be delivered to selected British customers as lease vehicles. The smart fortwo ev (electric vehicle) will celebrate its world premiere at the British International Motor Show (July 18th – 30th 2006) in London.
The vehicle will be driven by an electric motor with a power output of 30 kW / 41 bhp. The running costs per kilometre are considerably lower than those of a petrol-driven smart fortwo. And that’s saying something. While the smart fortwo, with fuel consumption costing approx. EUR 0.06 per kilometre, is already well ahead of its competitors, the smart fortwo with electric drive costs a mere EUR 0.02 per kilometre to run. Furthermore, the smart fortwo ev is exempt from the central London congestion charge.
At its best on short journeys in urban traffic
The smart fortwo ev’s driving performance is not to be sniffed at: it can accelerate from zero to 60 km/h in much the same time as its petrol-driven counterpart. It has a maximum speed of 120 km/h and economical consumption. 12 kilowatt hours per 100 kilometres gives it a range of 110 kilometres. These figures indicate that the smart fortwo ev is a vehicle that is ideal for short journeys in urban traffic.
It only takes three and a half hours to charge the battery from 30 to 80 percent of its capacity. An empty battery can be fully charged in no more than eight hours, for example overnight. The charging socket for the power cable is located underneath the filler cap, where the filler neck for diesel or petrol would be in other vehicles.
One forward and one reverse gear
No complex modifications are needed to fit the electric drive. The motor is located in the rear, exactly where the combustion engine would be in a conventional vehicle. The transmission, which has been locked in second gear, is likewise in the rear of the car. The smart fortwo ev therefore does not need the smart fortwo’s gearshift knob, since it only uses one forward and one reverse gear.
The charge level indicator for the battery is where the rev counter would be in other vehicles in a central position on the instrument panel, together with the analogue clock. But that’s all that has changed. The interior and the luggage compartment are just as spacious as before, and even the smart fortwo ev's power storage unit – a zebra or a sodium-nickel chloride battery is positioned centrally in the car's underbody.
Expertise in alternative drives
smart has already demonstrated its technological expertise in building alternative drives at the IAA 2005. The smart crosstown show car was fitted with a hybrid drive combining a petrol engine and an electric motor. Shortly after this smart presented several alternative drives at a technology forum and, in addition to a prototype of the smart fortwo ev, a smart fortwo with natural gas drive, a mild hybrid and a cdi hybrid were exhibited.
Pictures of the smart fortwo ev and of further cars made by smart are available at Daimler Global Media Site - Mercedes-Benz Cars - smart.
smart fortwo ev:
Technical data
Engine
Type Electric
Rated output (kW) 30
Power transmission
Transmission locked in second gear
Running gear
Front axle wishbone, McPherson strut,
anti-roll bar
Rear axle DeDion axle tube with central mount, wishbone,
coil springs, telescopic shock absorbers, anti- roll bar
Brake system hydr. dual circuit system with vacuum booster,
disc brakes at front, drum brakes
at rear, electronic stability programme esp
(incl. abs and brake force distribution),
brake assist
Steering rack-and-pinion steering, steering damper
Wheels front/rear 4 J x 15 – 5.5 J x 15
Tyres front/rear 145/65 R 15 - 175/55 R 15
Dimensions and weights
Wheelbase (mm) 1,812
Track width front (mm) 1,272
Track width rear (mm) 1,354
Length (mm) 2,500
Width (mm) 1,515
Height (mm) 1,549
Weight without driver (kg) approx. 844
Performance
Maximum speed (km/h) approx. 120
Range (km) approx. 110
kwagar is offline   Reply With Quote
Old 07-07-2008, 03:23 PM   #2 (permalink)
DHurt's Avatar
If the dealer will not offer a retrofit it looks like it can be copied fairly easily, or cannibalized from a wrecked smart ev.
DHurt is offline   Reply With Quote
Old 07-07-2008, 07:32 PM   #3 (permalink)
bottlerocket's Avatar
I WANT ONE!
Hopefully by the time my second reservation comes to a 90-day window it will be available. (early 2010?)
bottlerocket is offline   Reply With Quote
Old 07-07-2008, 07:49 PM   #4 (permalink)
Can you imagine a car with no internal combustion engine? No oil/filter,air filter,coolant to ever change. I think it was the Tesla car where the guy held the electric motor in his hands and it was no bigger than a watermelon. He also said one person could change the motor out in less than an hour. Now you see why there are so many people who don't want to see the electric car.
deltadart is offline   Reply With Quote
Old 07-07-2008, 08:05 PM   #5 (permalink)
Aye, except brakes, suspension, tires, etc. EVs are going to put a serious hurt on the auto repair biz(no clutch, simple trans, no tuneups, no emission system, no fuel pump, no muffler, no belts, its mind boggling).......I've seen AC motors/transmissions in industry go 15 -20 years of continuous service with nothing more than bearing lubrication........of course it remains to be seen if vehicle electric motors will be of this quality. I predict there will be lifetime warranties from most major manufacturers on the drivetrain.......of course, its the batteries that are going to be the fly in the ointment.....maybe we should open a battery repair/rebuild shop.
Ralph Finneren is offline   Reply With Quote
Old 07-07-2008, 11:14 PM   #6 (permalink)
a lot of wrecked EV's down your way
Old 07-08-2008, 03:41 AM   #7 (permalink)
you read my mind Karl.........
but back to the original post, it's dated 2006! this is 2008!! so, where's the smart ev NOW??
i really want one, but i'm getting tired of all this foreplay. why don't they just 'SHOW ME THE MONEY'!!!?
Old 07-08-2008, 08:01 AM   #8 (permalink)
I want one too , BUT with a better range then 68 miles!!!!!!
Old 07-08-2008, 08:28 AM   #9 (permalink)
i'm sure i could do better than the 68 mile range, as i'm pretty easy on the gas pedal....er, uh....well, whatever it would be called, i would be easy on it!!
Old 07-08-2008, 09:05 AM   #10 (permalink)
DHurt's Avatar
JFC
I'm fairly certain if smart evs are sold in the U.S. then it will only be a matter of time before they're wrecked and the parts cars can be purchased through ebay.
Radio 10 Specs ck_az Audio & Video 1 06-01-2008 08:33 PM
electric smart ms bea smart General Discussion 1 04-20-2008 12:03 PM
Electric Smart Car SnakeFarm smart General Discussion 9 03-26-2008 05:45 PM
Electric Smart iamchemist smart News & Rumors 10 11-14-2007 08:30 PM
451 Specs lhoboy smart fortwo (451 - US vehicle) 15 10-10-2007 08:54 PM
