Electrical wiring problems - Smart Car of America Forums : Smart Car Forum
Old 09-26-2008, 07:39 PM   #1 (permalink)
unicycle's Avatar
For a few months, i've had a problem with the brights: they flicker as tho I'm trying to send signals in Morse code. Thankfully I rarely use the brights, so this hasn't been a big issue....
Then I had a 6-CD changer installed by my dealership. Now I have a new trouble or two:
When I change gear from D to N, the radio/CD sometimes turns itself off and them immediately back on. And sometimes the radio just turns off-on of its own accord. And sometimes this happens when I put on the brights
Now oll have to take car back for a repair. Bummer
Old 09-26-2008, 08:48 PM   #2 (permalink)
Owner for 3.8 years
Kermit's Avatar
Check that ground wire - all the battery connections for that matter. Could just be loose....maybe.
Old 09-26-2008, 08:57 PM   #3 (permalink)
Ditto that Bum-bling-B! My installer wasn't about to do a flakey grounding job, knowing the issues they cause in the smarts. Guess I'm just lucky!!
Credit cubefx for the pic!!!
Old 07-05-2009, 12:54 AM   #4 (permalink)
Thanks for the advise. I, too, have been having problems with the headlights flickering and clicking when the brights are on, and the radio losing power. The ground wire was loose, however, it was the chassis end of the one running from the battery to the chassis. You can see the brown wire in the picture above, bottom center. A 10 mm wrench, and no more problem.
I mentioned it to my local dealer, who suggested that the problem may be originating when the battery is hooked up after being disconnected for shipping.
GOviatt is offline   Reply With Quote
Old 03-23-2011, 04:46 AM   #5 (permalink)
my car is at the dealer for same problem, lights flicker on hi, so far smart has no clue how to fix it. Waiting to hear from corp. office?
Bill.733
bill 733 is offline   Reply With Quote
Old 03-23-2011, 06:45 AM   #6 (permalink)
There are also grounding terminals in the rear to check
Old 03-23-2011, 07:14 AM   #7 (permalink)
Thanks for the info, as the dealership is just scratching their heads and tried a new headlight switch, which did not work.
Bill.733
Old 03-23-2011, 07:58 AM   #8 (permalink)
Happy 2012!
Bill I had my dealer look at my flickering head light issue, they attempted to tighten down the grounding posts and that was all they could do for me...
Old 03-23-2011, 08:03 AM   #9 (permalink)
did it work?
Bill.733
Old 04-06-2011, 08:56 PM   #10 (permalink)
possible next fix is the sim modual only $850.00. Still waiting for the results only been 4 weeks!!
Electrical Turnsignal Problem 2micro4u smart Operation and Maintenance 24 11-10-2011 09:05 AM
More electrical problems unicycle smart General Discussion 12 09-12-2010 08:24 PM
Electrical Interference thomasso New Members Area 6 02-11-2010 07:34 PM
Tech Help (electrical wiring) eddiealmeida New Members Area 7 11-03-2009 12:27 PM
...hummmm....interesting... (electrical) jetfuel smart General Discussion 1 01-08-2009 09:28 PM
