Florida lovebug removal? - Smart Car of America Forums : Smart Car Forum
Old 05-10-2008, 03:15 PM   #1 (permalink)
Ok, they are here and they are not coming off very easy.
Any suggestions on removal without hurting the finish.
flpat is offline   Reply With Quote
Old 05-10-2008, 03:44 PM   #2 (permalink)
SubSlr88's Avatar
Oh, my - how long have you lived in FL?
There are many solutions to the lovebug problem down here. Some say to spray the front end with PAM - it works but looks absolutely terrible and takes a really good washing to remove. Another technique is to wipe the entire front end down with a Bounce dryer sheet after wetting with a bit of water. The bug carcasses will then wash off easily.
Lastly, and the one I use, wax the front end and exposed frontal surfaces three or four times using a high quality wax. When you get into a bunch of the critters, hose them off immediately after getting home. Usually a good hosing is all that is needed. If they're really bad, a car wash with a high pressure hose will finish it up.
And don't forget to redo all of the protection again~!
If it ain't the alligators, it's the damned lovebugs!
Old 05-10-2008, 03:46 PM   #3 (permalink)
YES Harley Davidson bug remover. works well and can get at the nearest Harley dealer
txtrucker1 is offline   Reply With Quote
Old 05-10-2008, 05:15 PM   #4 (permalink)
kwagar's Avatar
Put a wet towel over the front end for several minutes to soften them up. I use Plexas plastic cleaner then and it works very well and polishes at the same time. Plexas available on many web sites.
kwagar is offline   Reply With Quote
Old 05-10-2008, 05:55 PM   #5 (permalink)
Some folks have posted good results using Rejex on the front panels; waiting for mine to arrive to try it out.
Old 05-10-2008, 06:00 PM   #6 (permalink)
HGB
HGB's Avatar
Love Bugs
Was told baby shampoo would loosen them. I haven't tried this yet.
I originally waxed the front of my car and poured a pail of water over the front after I arrived home. The plain water with gentle scrubbing, using a soft webbed design bug removal sponge worked well. This quick fix was followed with another pail of water poured over the areas in question. Done.
Old 05-10-2008, 06:02 PM   #7 (permalink)
Thank you, am going to try the bounce dryer sheet wax, rejex, will have to get some. thank you all for the suggestions. We have some harley bug remover but these suckers are horrible. How was the party at the smart dealer?
Old 05-10-2008, 07:25 PM   #8 (permalink)
dbwill's Avatar
flpat, don't use wax under Rejex. If you do the rejex will not cure properoy and will not stay on
Old 05-11-2008, 06:35 PM   #9 (permalink)
The bounce dryer wipe worked great!
Old 05-11-2008, 06:51 PM   #10 (permalink)
Nicholas's Avatar
Make sure you use a "good" quality dryer sheet, a cheap brand doesn't seem to work...must be the amount of chemical in the sheets
451 interior header removal randyzimmer smart Operation and Maintenance 14 04-10-2011 10:39 PM
Door panel removal Westfield 11 smart General Discussion 5 02-20-2009 11:11 PM
Grill removal smart i am Interior & Exterior 19 06-17-2008 10:57 PM
Inside Door Panel Removal Agent86 Interior & Exterior 1 04-15-2008 06:25 AM
451 lower windshield molding removal randyzimmer smart Operation and Maintenance 3 03-20-2008 09:10 AM
