Originally Posted by forestacademy
Well I find that hard to believe unless the fuel sender was faulty as most of us have driven anywhere from 0 to .. oh I don't know.. 30 miles pass the 0.0 on the gauge, actually I do that all the time
If I have to do I'll document that too LOL...
But I started this thread not about how many miles you can drive past 0.0 as the gauge is dependent on the fuel sender, I started this to talk about the actual size of the tank and only the tank itself.
I also forgot to mention... the video I took is a fact... what someone elses says is just words not saying that people are lying but... due to the shape of the tank, and the height of the fuel pick up... if you drive aggressively in terms of speed, deceleration and/or cornering you could run the tank down to the point where even if there was a gallon left in the tank, the car WILL NOT START because there isn't enough fuel to prime the fuel pump. There is a fuel BOWL or BUFFER with a one way VALVE under this bowl, if you drive aggressively fuel is sloshed around and ALL it takes is the car to sputter and the ECU wont let you start the car because there isn't enough "height of fuel" in the tank to prime the fuel pump.
If you do run out of fuel right after 0.0 gal on the gauge, the next best thing you can do is turn the car on and off 3 times, not starting it, but turning it on and off and then try to start the car. The ECU will allow you to prime and start the fuel pump 3 times before it wont trigger the fuel relay UNTIL you start or try to start the car. I know because I've been playing with the fuel system on the smart car for the last 2 months. With the car stationary you might have enough fuel to prime the fuel rails again and get the car to start and GENTLY drive to the nearest gas station.
I know when I get down to 0.0 on the gauge I drive the car VERY conservatively just to keep the fuel from sloshing around inside the tank only because I know the shape of the tank and how our smart car picks up it's fuel. One hard acceleration is all it takes for the fuel pressure to drop due to the fuel pump's pick up not being submerged in fuel in the buffer.
Larry
