Gas Tank Top Off - Smart Car of America Forums : Smart Car Forum
Trailer
Old 04-02-2008, 09:30 AM   #1 (permalink)
Gas Tank Top Off
On my first gas up some one was talking to me about my Smart and I was not paying attention. I ended up over filling the tank. I mean it was to the top. I know your not suppose to do that. My question is that I have driven 72 miles and the gas tank still says full. Is this do to the extra gas I put in when overfilling or did I maybe mess up some sensor?
sbernali is offline   Reply With Quote
Old 04-02-2008, 09:34 AM   #2 (permalink)
you can overload the evaporative system (charcoal cannister) don't worry just keep driving. I would not recommend doing that again, others do it all the time...
Old 04-02-2008, 10:07 AM   #3 (permalink)
I have found that the gauge is not very linear - when I fill up the first rectangle disappears after about 80 miles, then each successive rectangle disappears after about 30 miles...
Alan_Hepburn is offline   Reply With Quote
Old 04-02-2008, 10:27 AM   #4 (permalink)
BandSofC's Avatar
I've observed the non-linearity also.
BandSofC is offline   Reply With Quote
Old 04-02-2008, 10:41 AM   #5 (permalink)
this is not uncommon for a vehicle to not keep a consistant tank reading. I know many cars that will say F for many day and then suddenly you can actually watch the gauge go to 1/4 from E in under a minute. I do wonder if this has something to do with toping off the tank. I dont know why people are so concerned with getting every last drop into their tank, but many people even shake their car to get the last amount they can into the tank. Toping off a tank as I am sure you have heard is bad for the tank mechanics. When at the tank a good practice is to stop when the pump clicks the handle down and if odd numbers bother you, go to an even cent value...lol
Krodista is offline   Reply With Quote
Old 04-02-2008, 11:04 AM   #6 (permalink)
You are probobly filling the filler neck with the tank...should we all junk the car before.......
Old 04-02-2008, 03:31 PM   #7 (permalink)
RussBarnes's Avatar
Today’s cars use a vapor trapping system aka, carbon canister. That lets air into the fuel tank to make up for the liquid fuel that you remove. The carbon is a large filter medium that filters the raw fuel from evaporating into the air when the car is at rest and the vapors try to flow the other way. If you overfill too much on some cars you can force fill the carbon, wetting it and then the air doesn’t pass. When that happens the fuel doesn’t flow “so good” to the engine and things are unhappy in engine land.
OK to stop customers from doing that many car manufacturers do two things. First they extend the end of the fill pipe into the tank so that even when fuel is pumped back up the filler there is usually about a 5% expansion area to prevent true overfilling and also to allow room for expansion when you fill and park in the sun. So when you “overfilled” you really didn’t – except for the note below (*).
Second, to allow the system to be closed and not give Al Gore a runny nose from gas vapors the cap seals the system and when it is screwed back in it opens the line to the canister. If the cap is left loose then the system is open to the air, the air isn’t flowing through the carbon trap and another sensor detects it and the warning lights go off. Some of you that took physics can see that this has to be this way because if the cap closed tight air couldn’t come in then the system wouldn’t pump either. So to prevent owners from pumping fuel back into the canister these manufacturers use that valve and this is the case on the smart. Look inside toward the front of the filler neck when you have the cap off (DON’T USE A LIGHTER) it is hard to see but there is a small, black (+/- Ľ”) plastic gismo that is sticking out the neck.
Here is where the (*) note comes in. If you fill where I do the Wal-Mart has a ridge on the neck of the gas nozzle that can trip my trigger…..so to speak. When it happens I can hear the sound of the gasoline bubbles bursting in the top of the tank because the vapor hose is now open, but not to the carbon canister, but where I am pumping. This overfilling can flood the canister. I even use this knowledge to my advantage. I HATE TO TAKE THE TIME TO FILL, so I usually buy cars that go a long way between fill-ups. My daily driver goes about 800 miles which means I stop once a week, I hated the last car because it would only go about 450 and that wasted at least 20 minutes a week from my life doing something that is boring. I don’t drive the smart to commute, so not an issue. HOWEVER, when I fill my smart, if I know that I am going to drive another 15-20 miles before I shut it off for the day, I use the end of the nozzle to trip the valve and then I do get more in, but not up the neck. Yes, I risk saturating the canister, but a risk I choose, on my own.
275 miles on first tank of gas sbernali smart General Discussion 4 03-25-2008 01:10 PM
275 miles first tank sbernali New Members Area 4 03-25-2008 11:53 AM
Has anyone used a tank of ... Smartfor2guy smart General Discussion 8 03-20-2008 10:21 PM
Gas Tank Filler Door COLOR pagja smart General Discussion 9 10-26-2007 04:23 PM
Do you think the gray market cars resale value is going to tank when the 2008 Norahs_dad smart General Discussion 27 10-17-2007 06:03 AM
