Hard start with warm engine. - Smart Car of America Forums : Smart Car Forum
Old 05-13-2008, 06:00 PM   #1 (permalink)
Has anyone else had an issue with the engine not starting on the first try when the engine is warm/hot. What I am have happening is, if I drive to the store and come back out to leave the store in about 10 to 15 minutes the engine will not want or try to start on the first try. If I turn to key off completely then try to start it the second time, it starts just fine. This only happens when the engine had just been running a short period of time before, not on cold starts.
smartie1 is offline   Reply With Quote
Old 05-13-2008, 06:17 PM   #2 (permalink)
Senior Smartie
jonnysan's Avatar
Are you......
holding the key in the start position for a long enough time or do you wait a second or two after turning the key to the ON position before moving the key to the start position? There is a delay between the actual key movement and the boot-up of the EEC that is normal.
Shifter in Park fully?
Old 08-12-2009, 06:27 PM   #3 (permalink)
Hard start with warm engine--RESOLVED.
The problem finally was resolved. It would lose 4 or 5 pounds of fuel pressure. So at a warm start it would shut down the needed systems to start the engine. With the first try of cranking to engine the fuel pressure was restored to the correct pressure and would pop right off with the next attempt. The fuel pump assembly was replaced to correct this issue.
Old 08-13-2009, 07:41 AM   #4 (permalink)
Thanks for the update..........
Would it be hard? Hello smart General Discussion 7 04-25-2008 01:57 PM
Hard Working Smart Car. a2jack smart General Discussion 5 04-24-2008 12:31 PM
smart warm up time? sbernali smart General Discussion 10 04-05-2008 07:51 AM
Hard to find facts... Please contribute Fredvon4 smart fortwo (451 - US vehicle) 13 03-20-2008 06:39 AM
How hard will you beat your new smart? a2jack smart General Discussion 10 01-10-2008 05:29 PM
