Headlights intensity changing while shifting... - Smart Car of America Forums : Smart Car Forum
Old 04-08-2008, 08:26 PM   #1 (permalink)
Amethyste's Avatar
Tonight I was coming back from a friend and I noticed that my headlights intensity would change when I was shifting: Per axample, when I would shift up, there would be a small, but detectable variation in "the power that the headlights are putting out", then would come back to normal as the car went through the gear change. I didn't detect a change when shifting down.
It's not really a big deal, I was just wondering if one of you noticed that as well?
Amethyste is offline   Reply With Quote
Old 04-08-2008, 08:43 PM   #2 (permalink)
hmmm, are you sure that the car isn't lifting in the front when you shift to a higher gear, causing your lights to appear brighter? Just a thought since it's been reported that the suspension is very soft. Obviously when you downshift the car would dip in the front, but maybe not enough to notice less light?
toogrvy is offline   Reply With Quote
Old 04-08-2008, 08:57 PM   #3 (permalink)
Amethyste's Avatar
Actually, the intensity of the headlights is seems lower when I upshift, like its using "juice" from the alternator and resume to normal after the gear change has occured.
Old 04-09-2008, 07:46 AM   #4 (permalink)
Supporting Tuner
Evilution's Avatar
Right answer, wrong conclusion.
As the car tips back the headlights are focused further down the road so less light returns so they seem darker.
Quite often people will think you are flashing your lights at them as you pull away and change gears.
Old 04-09-2008, 08:11 AM   #5 (permalink)
Founder/former Admin.
SMART's Avatar
Ah, makes sense with the enormous amount of lift from the front end when taking off...
Old 04-09-2008, 08:38 AM   #6 (permalink)
Perception vs Reality
Half of my commute is in the dark and I did notice the same thing and wondered if it was reflections that made it look that way or what the deal was. It did appear to momentarily dim.
my car is not doing all the bobbing anymore...
Old 04-09-2008, 09:01 AM   #7 (permalink)
eqwalker's Avatar
Actually, it is causing a dip in voltage from the alternator. I have noticed the same thing since day one and really haven't paid it much mind, other than it is a regulator issue. When the solenoids operate in the tranny, it causes it. Mine is not due to the car "tilting" when the shifts occur since I have seen it with the A/C kicking in and out as well as the cooling fan in the front kicking on and off while the headlights are on. I suspect that it is a normal occurance on this vehicle.
Old 04-09-2008, 09:08 AM   #8 (permalink)
you would think that a car this dependant on the electronics would have a smoother power supply.
Old 04-09-2008, 09:21 AM   #9 (permalink)
eqwalker's Avatar
Yes, you would think. There will probably be a third party solution sometime in the future (possibly a change to the existing alternator or a new alternator altogether) that will address this for those of us that want to eliminate it.
Old 04-09-2008, 09:30 AM   #10 (permalink)
SmartDigger's Avatar
Better Ground and a bigger battery would do the trick.
Broken Headlights! Please Help! matweekly smart Operation and Maintenance 6 06-08-2008 10:26 AM
Blacked out headlights SMART Interior & Exterior 12 04-12-2008 04:32 PM
Headlights SloPok smart fortwo (451 - US vehicle) 7 03-01-2008 01:10 PM
changing colors? christara New Members Area 7 02-04-2008 08:13 PM
