Help - clutch or transmission problem?? - Smart Car Forums
post #1 of 14 (permalink) Old 11-13-2010, 05:23 PM Thread Starter
OTD3 lifetime Member
Quoted: 32 Post(s)
We are getting the following error codes:
U0073: control module communication bus off
U0103
The check engine light is on as well as the Triangle with ! point inside.
The car acts like either the clutch isn't engaging or it has a transmission problem. It jumps into gear, intermittently. It has also has acted like it wan't going to go into gear - refuse to move but the engine revved up.
Any ideas on what is going on and any quick, easy fixes would be appreciated. We are outside Kingman, AZ and needing to drive back to Oklahoma on Monday.
Is this problem going to strand us part way home?
Can someone put this under the right forum, Please
jkjahobbs is offline
post #2 of 14 (permalink) Old 11-13-2010, 05:26 PM
banned
I moved the thread to Gen discussion... I don't have the first idea what the solution is...
Wdhitch is offline
post #3 of 14 (permalink) Old 11-13-2010, 07:05 PM
To the XCAPEPOD!
rfernatt's Avatar
Quoted: 63 Post(s)
We've seen other communication bus errors that were related to having something plugged into the power socket. Definitely pull anything plugged into that and see if it makes a difference. And, anything plugged into the OBD port could also be suspect.
Since everything communicates on that bus, including the transmission control module and ABS/ESP systems, something may be interfering with communication.
If that doesn't help, you could try disconnecting the battery for 15-20 minutes and let everything reset. You may have to reteach the transmission afterwards, but that's an easy 30 second procedure detailed in the manual and might not be a bad idea regardless given your description. I've done mine a few times when I even think it might be hesitating to engage a gear.
If you don't have any luck with these steps, it may be an electronics issue and a trip to the nearest smart center for a detailed diagnostic would be in order...
rfernatt is offline
post #4 of 14 (permalink) Old 11-13-2010, 07:09 PM
SmartDigger's Avatar
Quoted: 176 Post(s)
You might be needing a new clutch motor, I would try to reset first.
SmartDigger is offline
post #5 of 14 (permalink) Old 11-13-2010, 07:15 PM Thread Starter
Quoted: 32 Post(s)
Thank you for the suggestions. We've already done the unplug from the power socket and disconnecting the battery.
We will try the transmission reteach in the morning as well as disconnecting the battery again.
I'm hoping we can make it home before we have to visit a smart center.
post #6 of 14 (permalink) Old 11-13-2010, 07:20 PM
To the XCAPEPOD!
rfernatt's Avatar
Quoted: 63 Post(s)
Do you happen to have a cruise control or any other modification that is tied into the car's systems? That could be something else to check/remove/bypass.
Also, here's a couple threads that have mentioned those codes and what it might be related to:
http://www.smartcarofamerica.com/for...al-codes-33508
http://www.smartcarofamerica.com/for...reciated-32014
rfernatt is offline
post #7 of 14 (permalink) Old 11-14-2010, 11:06 PM Thread Starter
Quoted: 32 Post(s)
Jim disconnected the Ultra Gauge, uninstalled the cruise control, nothing is plugged into the power port, disconnected the battery for over 20 minutes, tried to reteach the transmission, that didn't seem to happen.
Jim had one episode on a 40 mile test drive. We decided to only drive it in manual mode. We have now driven 225 miles without a problem. Hopelly we can go the 930 with no difficulties as well.
Thank you to all of you for your help and suggestions. They were helpful.
Jill
post #8 of 14 (permalink) Old 11-15-2010, 07:44 AM
a2jack's Avatar
Quoted: 64 Post(s)
JKJ. I wish you Good luck getting home. At least it's mostly down hill from Kingman. A2Jack.
a2jack is offline
post #9 of 14 (permalink) Old 11-15-2010, 08:28 AM
Toolman's Avatar
Quoted: 1 Post(s)
I missed this one over the weekend. Keep us updated, and best of luck! Hopefully you'll be home maybe late tonight?? My mom lives in Mesa, and I think it's about a 16 hour drive from there to Fort Worth.
Toolman is offline
post #10 of 14 (permalink) Old 11-16-2010, 08:51 AM Thread Starter
Quoted: 32 Post(s)
Toolman: Thanks, Winslow, AZ to home was 18 hours but that included an hour stop at a museum and a 30 minute stop for dinner. So 16 hours driving and gas stops. Meadeview to home is 20 hours with only gas and potty stops.
Made it home with no further problems. We talked to Rachel at Smart Madness and she suggested that when the dealer did the software updates recently it may have flashed the cruise control and caused the communication and thus the transmission or clutch problem. She thinks it needs to go back to the manufacturer for ??reprogramming?? or something.
They are exchanging the cruise control for us. Thank you for the help Rachel.
We used the power port and then the ultragauge for the last part of the trip home and had no problems and no ESP triangle and the engine light did not come on.
Human Verification
331
New Transmission Problem redbluff smart Operation and Maintenance 29 07-11-2010 08:02 PM
First Clutch Problem Butch smart Operation and Maintenance 12 04-13-2010 02:39 PM
New Transmission Problem Wildbill1975 smart Operation and Maintenance 9 08-05-2009 09:49 AM
Problem With Gear Transmission KIMTEH New Members Area 0 07-27-2008 10:20 AM
Is there a problem with the Getrag Transmission? SMART smart News & Rumors 55 07-25-2008 05:43 PM
