High beaming from other cars - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 11-11-2008, 06:00 PM   #11 (permalink)
Owner for 3.8 years
Kermit's Avatar
Your right about that, I noticed when another Smart was behind me the other day that when the car shifted it looked like they were flashing the brights.
Old 11-11-2008, 06:08 PM   #12 (permalink)
Originally Posted by forestacademy View Post
Now, the actual problem is the fact that the car has a stiff ride and the headlights bounce a lot, so the fix is to get a smoother suspension or ride on smoother roads.
I've rarely heard a characterization so far out of sync with my own perception. The Smart suspension seems "sloshy" to me - not enough responsiveness. I associate this with a soft suspension rather than stiff.
By changing to stiffer aftermarket springs, the lunge forward, whip back bobble-head phase of shifting is significantly reduced. Hitting bumpy asphalt will now result in the car bouncing around more (being more responsive) but not to where the headlight angle dashes up and down. A rigid car tends to stay parallel to the road compared to the boat I inherited from the factory.
Old 11-11-2008, 06:24 PM   #13 (permalink)
HGB
HGB's Avatar
Read on
Old 11-11-2008, 06:25 PM   #14 (permalink)
Oh Yeah, I forgot about that asect of the smart, The not so smooth shift bounce/flash.
Old 11-11-2008, 06:35 PM   #15 (permalink)
HGB
HGB's Avatar
I still say they lights are aimed to high at the factory, because when I put the highs on they seem to light up more than the road and I'm not interested in anything but the road. So I adjusted them down and after several tries... within a week or so I found that sweet spot. By doing that I respect the projector beams more than ever now and I will not waste money on XENON bulbs unless the high beams were also changed and that's a whole other issue.
Old 11-11-2008, 06:44 PM   #16 (permalink)
HGB
You said that
Old 11-11-2008, 06:44 PM   #17 (permalink)
burtandnancy's Avatar
I'm on my second smart, and agree that the lights are set a bit high. I also think the tire pressure was way too high as well, must be that French altitude...
Old 11-12-2008, 07:19 AM   #18 (permalink)
it makes sense that a slight bob could appear as high beaming. if you look at the car in front of you, you do see that sharp upper cut off. beacuse that cut off is set "X high", when you go over a bump or the car bobs, that cut off is seen going up and down from the oncoming car as a flash. however, "X high" could be too high...
andy'smart is offline   Reply With Quote
No, These are Not My High Beams! Thru the Eyes of Ruby smart General Discussion 8 07-31-2008 12:45 PM
The Key to High Mileage jwight Technical "stickies" 0 07-01-2008 08:20 AM
The high cost of AC nickpiketx smart General Discussion 17 06-17-2008 07:25 PM
High gas prices fuel demand for smaller cars jwight The Car Lounge 8 04-28-2008 09:46 PM
Very High Quality Videos MicroNut smart Videos 0 10-26-2007 11:23 PM
