How can I active Coming Home Lights? (autolight feature) - Smart Car of America Forums : Smart Car Forum
Old 02-09-2010, 07:42 AM   #1 (permalink)
Hello from Spain!
How can i active coming Home lights in my smart?
Thanks!
santifor2 is offline   Reply With Quote
Old 02-09-2010, 08:00 AM   #2 (permalink)
By "coming home lights" do you mean turning on the lights in your home when you approach? The home-link system of remotes and accessories should give you the opportunity to turn your home lights on with the push of a button from inside your car.
Old 02-09-2010, 08:06 AM   #3 (permalink)
I think he means the coming home light feature of the autolight function. Found this in another thread:
The tech manual also states on page 101 that the "Coming-Home function" is only a component of the autolight function. "The function is a component of the Autolight Function. When the vehicle is locked or unlocked, the driving lights are switched on for 12 seconds. The function is also activated by the rain sensor/light sensor; the position of the combination switch is immateral. The Coming-Home function can only be deactivated by coding in the workshop."
Have to have the autolight function; sounds like the coming home feature is activated by default from the last sentence above.
Old 02-09-2010, 08:19 AM   #4 (permalink)
Thanks John_H and jwight!
Yes, jwight, these functios is coming home!
Is possible active this function without go to workshop?
THANKS!
Old 02-09-2010, 08:22 AM   #5 (permalink)
Do you have the autolight feature on your smart? If so, it appears (not positive as our car does not have autolights) the coming home lights should be active.
Old 02-09-2010, 09:42 AM   #6 (permalink)
THANKS!
You MUST have the autolight feature (big hockey puck on windshield). IF you have this, then you already have the "coming home" lights, if not, then you are out of luck
chieftmc is online now   Reply With Quote
Old 02-09-2010, 10:29 AM   #7 (permalink)
Mister P's Avatar
Mister P is offline   Reply With Quote
Michelin Active Wheel System Smart Enuf The Car Lounge 3 01-02-2009 01:23 PM
Auto lights feature and DRL jwight smart General Discussion 29 07-25-2008 07:05 AM
Active Body Panels SnakeFarm smart General Discussion 17 07-23-2008 03:55 PM
active or passive Periclaws New Members Area 6 07-22-2008 09:53 PM
