If MPG drops, check PSIs more frequently! - Smart Car of America Forums : Smart Car Forum
Old 07-14-2008, 09:46 AM   #1 (permalink)
stevenvillatoro's Avatar
Just thought I'd post a quick important reminder to check your tire pressures frequently.
My MPGs were dropping... I hadn't realized that several months had FLOWN by already since checking tire pressures. Sure enough, I had lost 4 PSI in the rear tires and 2 PSI in the front ones.
Did a quick fill and boost to the fronts to test (31/36 rather than 29/36 previous), and can already notice more miles-per-bar.
If it's been a few weeks, go check your tire pressures!
Old 07-14-2008, 09:52 AM   #2 (permalink)
SharonRB's Avatar
Thanks for the tip! I'll have hubby do it tonight for me. I was going along great on my current tank -- 35 miles on the first bar (not great), but then 56 miles on the second bar and I thought I was on my way to a great tank! then I got 10 miles on the third bar and 16 on the fourth. I'm thinking, "WTF?" The 5th is going a little better, but none of this made sense to me. Your tip is very timely. If my pressure isn't down, though, I'm going to be totally stumped.
SharonRB is offline   Reply With Quote
Old 07-14-2008, 10:03 AM   #3 (permalink)
I can't even imagine the MPBs (Miles Per Bar) that you're reporting. I think the smart could get that good with the tires totally flat!
Old 07-14-2008, 10:03 AM   #4 (permalink)
dcrooks's Avatar
Shouldn't the sensor kick in? Or when does the tire pressure sensor kick in???
dcrooks is offline   Reply With Quote
Old 07-14-2008, 10:11 AM   #5 (permalink)
SharonRB's Avatar
Yeah, it's pretty bad this tank. I typically get between 40 and 52 on the first bar, then in the 20s on bars 2 and 3 and then usually around 35-45 on the last five bars.
My overall mileage is typically 35-39, although it was only 32 on one tank and 40-42 on a couple of tanks.
Old 07-14-2008, 10:32 AM   #6 (permalink)
Senior Smartie
jonnysan's Avatar
Sharon.....Using the....
AC any at all will cause that....
Old 07-14-2008, 10:34 AM   #7 (permalink)
I use A/C 95% of the time, and normally get near 40 MPG with a lead foot.
Old 07-15-2008, 11:22 AM   #8 (permalink)
SharonRB's Avatar
I rarely use my AC -- I have the top down all the time unless it's raining. I did have to use it a little bit this weekend, but not much.
Hubby checked the tires for me last night, and I definitely needed some air. He said a couple of the tires were down 5 lbs. Hopefully that will help, although I did get 41 miles on the fifth bar, most of which was driven before airing up.
Old 07-15-2008, 11:29 AM   #9 (permalink)
NY Smartie's Avatar
that's a huge amount on tires as small as ours. I bet you notice a big difference. good luck!
Old 07-15-2008, 11:35 AM   #10 (permalink)
SharonRB's Avatar
Thanks! It sounded like a lot to me, too. I think the rears were way down and the fronts were down by a pound or so. I'm leaving town tomorrow for Austin for five days, so I won't really know until next week if it really helps.
Minnesota Check-In propes Minnesmarta Chapter 276 10-15-2008 08:14 AM
Check this out... fuelpincher smart Videos 5 04-25-2008 07:52 AM
Check My Math SnakeFarm smart General Discussion 3 12-20-2007 11:37 PM
