Installation help for Basic Rack - Smart Car Forums
 2Likes
  • 2 Post By jzchen
post #1 of 7 (permalink) Old 06-05-2017, 07:07 PM Thread Starter
Quoted: 1 Post(s)
I purchased the basic rack second hand and don't have the installation instructions. There are two small aluminum tubes with rubber caps that extend underneath the tailgate but don't seem to connect to anything? There is a hole in each rubber cap that was apparently put there for a reason but yet there's nothing to connect these to. Thanks!
desotodino is offline
post #2 of 7 (permalink) Old 06-06-2017, 08:47 PM
King of Smart Gadgetry
DreamCarOwner's Avatar
Quoted: 244 Post(s)
There are several different versions of a bike rack that was available for the Smart. There is a couple of metal pins that stick up through the air vents that may be what you need for your installation. You can see them in this picture. The driver side sticks up right above the turbo emeblem and the passenger side is right there beside my trailer connector wire. If this helps I might be able to find a picture of them with the rear plastic off.
DreamCarOwner is offline
post #3 of 7 (permalink) Old 06-07-2017, 04:08 AM Thread Starter
Quoted: 1 Post(s)
Thank you, this helps a lot. I can see now how it would lock on once placed on those pins and the bolts to the bumper secure.
post #4 of 7 (permalink) Old 06-07-2017, 05:23 AM
DowneasTTer's Avatar
Quoted: 56 Post(s)
If you have the OEM model you are probably missing the major part of the rack. There is a quite a bit of rack structure that going under the skin of the 451 if I remember you need to remove the back end plastic and add the internal structure that the basic rack for one or two bikes mounts to. That's one of the reasons most of us purchased a hitch type solution. Good luck and I hope I'm wrong.
DowneasTTer is offline
post #5 of 7 (permalink) Old 06-08-2017, 06:55 PM Thread Starter
Quoted: 1 Post(s)
I'll probably go that route, I have a bike rack already so I think that makes a lot of sense. My hesitation to go that way was the low clearance but it seems many have done so successfully already.
post #6 of 7 (permalink) Old 06-15-2017, 02:19 AM
Quoted: 349 Post(s)
The two pieces are not very big, but do require taking the rear "CBS" off. I quote CBS because somehow I remember that, but don't remember what it stands for. Basically you have to remove the side skirts and then the rear bumper, which IIRC requires unscrewing the rear hatch bottom. I still recall my son telling my dad that I was actually "crying" during the install... One needs to drill 4 holes for each of the brackets. There were screws provided that needed to be torqued to a specific value. If it started to give, then pop rivets could be used. My EPC subscription just ran out, but I tried to take a peak for the parts/part numbers just before it expired and didn't see them....
Sorry about that. Lots going on. Probably find out today whether they total my smart or not. Geez it took a long time to estimate the damage.....
jzchen is online now
post #7 of 7 (permalink) Old 06-23-2017, 10:07 PM
Quoted: 349 Post(s)
Human Verification
Need basic help - front and rear speaker installation stasha Audio & Video 18 03-13-2017 10:37 PM
Basic rack for towing Riccawthra smart Towing 0 07-20-2016 10:32 AM
Smart Car Basic (Bike) Rack Replacement Bolts? cree8art smart General Discussion 10 07-13-2014 04:28 AM
HELP! Being overcharged on ski rack installation dsweiner smart General Discussion 3 12-16-2008 12:33 PM
Basic Rack Accessory: Storage Trunk for X-Tra Luggage? LorbeerTLC smart General Discussion 1 01-28-2008 09:57 AM
