lift your foot when shifting or not? - Smart Car of America Forums : Smart Car Forum
Old 05-12-2008, 04:50 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
there have been several threads touching on this question...
Do you lift your foot off the gas when shifting in manual mode?
Our salesman told us to lift our gas foot quickly when shifting, but I have read very convincing arguments against this advice on this forum.
For the last week, I have not lifted my foot at all. What have I found?
- my transitions are smoother
- my acceleration is quicker
- my car lurches less and seems happier
However, I have a lingering feeling I am doing something wrong (I've always done what I'm told!)...
Can any of you experts out there reassure me?
Can you explain why our salesman (and many others apparently) tell customers to lift their foot?
Thanks!
Holly in Indianapolis
aslusers is offline   Reply With Quote
Old 05-12-2008, 04:55 PM   #2 (permalink)
SmartShanna's Avatar
Well, it's not really a lift as much as it it is a subtle shift in weight on the gas pedal. It's quite intuitive and fun, too.
Oh, and about always doing what you are told**life is way too short for that! Experiment, live, make mistakes, and most of all, enjoy your smart!
Cheers,
Smartshanna
SmartShanna is offline   Reply With Quote
Old 05-12-2008, 05:05 PM   #3 (permalink)
bottlerocket's Avatar
I think it's TOTALLY subjective
I don't lift my foot off at all, actually I do the opposite which is squeeze it at least half way to two thirds down. I actually enjoy the transmission but I guess I'm an outlier on that....
I think the car is happier when you squirt it some gas IMO
bottlerocket is offline   Reply With Quote
Old 05-12-2008, 05:26 PM   #4 (permalink)
factor9's Avatar
I go along with Shanna, all I'd add is that I seem to ease off the gas just a bit when shifting into 2nd and 3rd, but keep it steady for the higher gears. I've read posts that the less you keep adjusting the gas, the better your mileage. However, when I do need to get by someone, I "squirt it some gas" as was mentioned.
factor9 is offline   Reply With Quote
Old 05-12-2008, 05:54 PM   #5 (permalink)
In my opinion, moving the throttle pedal while shifting can “confuse” the computer, as it is trying to sync the throttle, clutch and transmission. The computer does its throttle modulation back at the engine and I believe that it slows down the shift when the throttle pedal is in a different position as the clutch is re-engaged vs. when it was dis-engaged.
I believe that, given the chance, the Smart does a very good, consistent job of shifting under MOST circumstances.
I could be wrong… I have been before!
Old 05-12-2008, 05:58 PM   #6 (permalink)
Senior Smartie
jonnysan's Avatar
Once the car has been broken in...
and the same person has been driving it, I have found no need to lift on the accelerator in either auto or manual mode. The correctly trained car and transmission (correctly according to how I drive it, that is) shifts just fine and damnit if it almost doesn't sense that I am thinking it should shift down or up and it does!!! Pretty smart car If you ask me!! LOL
I am totally at ease with the transmission now after 2500 miles of trouble free driving and think having the option to use it either in manual OR automatic is quite advanced as far as transmissions go.
John
Old 05-12-2008, 06:11 PM   #7 (permalink)
Luigi 1's Avatar
I have to agree with the above. The computer is synchronizing the thottle with the clutch, disengaging the transmission at the specified RPM rate. I was also told to lift slightly of the accelerator pedal to make the shifting "smoother," but as a race car (F1) enthusiast I would say that most people will not have the finesse to out "Smart" the computer. The computer might only become "confused" from the incorrect readings brought by the mild adjustment to the throttle and might not engage the next gear reliably.
Luigi 1 is offline   Reply With Quote
Old 05-12-2008, 06:14 PM   #8 (permalink)
As a smart brand specialist, I've found that the "lifting the foot" method only really is necessary in Drive mode, not in the manual. In manual, you can just keep your foot down. However in Drive, there's no way I wouldn't ease off the gas. Now, actually lifting your foot off of the pedal isn't a good method either, but rather just ease up and stop applying the same pressure. That's what I generally tell people to do, not because of instruction from smart, but because it's what works. If you ease off slightly, it is a much, much smoother shift transition in Drive mode.
Manual though? Let loose and keep 'er down.
- Nathan
BHSpecialist is offline   Reply With Quote
Old 05-12-2008, 06:34 PM   #9 (permalink)
From Autocar Magazine
Quoted in the NY Times articles thread:
Use auto mode to drift about town, and you’ll hardly ever notice the “nodding-dog” problems of old. Change with the lever when driving harder, and you’ll actually enjoy the performance. The ‘box even blips nicely on downchanges.
I have to agree with the first part; I started off lifting slightly as the car shifted but now just keep a constant throttle position. If you're at about 1/4 throttle you do get some "nodding dog" action at slower speeds. However, it's my experience that at 1/2 throttle or better the shifts are much smoother. To each his (or her) own, but I've stopped the slight lift on the throttle and haven't resorted to the manual mode much at all. The car will do whatever you want in "D" - all you have to do is let it know via the throttle.
Old 05-12-2008, 06:53 PM   #10 (permalink)
- Nathan
Nathan-
did Smart train you to tell customers to lift up on the gas pedal? If so, why? Seems if it isnt necessary, (and better without this move), then why bother?
Is there some engine saving benefit from lifting up when shifting?
Thanks-
holly
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f4/lift-your-foot-when-shifting-not-6616/
Untitled document This thread Refback 05-17-2008 07:05 PM
Shifting ? SmartDigger smart Operation and Maintenance 11 04-21-2008 09:47 AM
Up on the lift.. Frankenstein_Casanova smart General Discussion 2 04-13-2008 09:31 PM
Lift Points? doc540 smart Operation and Maintenance 16 03-05-2008 10:59 AM
Smart car on a standard lift canon1753 smart Operation and Maintenance 1 02-25-2008 11:08 AM
Lift kit for a fortwo roverallover smart Gallery 9 11-21-2007 11:49 PM
