Originally Posted by yellow-smart
Somewhere on this forum site someone was working on a checklist that you should use when picking up your car. I think it would be a good thing if you could locate this and use it to get the dealer to go over your car with a fine tooth comb.
It had a list of like 15-20 things you should consider.
Yellow-Smart
Well, I went over most of the check list, and it was pretty solid. Having a bad Component, IE throttle body, you can't see that. It just goes bad. IE having a leak in the radiator after the car has been heated and cooled for 3 days. You can't check for that. As for the connector, well I would physically have to go and check each connector. Not possible when I had to get back to work. No worries, car runs great except for this one issue that is on going right now. Hoping it can be resolved quickly. I do not like driving this rental FORD FUSION. Stinks like smoker too.
Oh, and as for the List, the dealer does pretty much the whole list before you get there. Round Rock is the Best as far as I am concerned.
