Loose engine compartment insulation. - Smart Car of America Forums : Smart Car Forum
Trailer
Old 04-15-2009, 07:00 PM   #1 (permalink)
Greetings..Had a friend stop by today to let me know he had done his first oil change, but more importantly to have me check to see if the little "wing nuts" that hold the insulation up in place in the engine compartment were tight as his were loose and almost ready to fall off!
A quick check of mine found the same problem and a check of another friends smart showed the same.
With the lid off the engine compartment there are about 6 of these fasteners about the size of a quarter under the lip that thread on a stud and hold the insulation up in place.
You may want to check yours.
SLIVERS is offline   Reply With Quote
Old 04-15-2009, 07:08 PM   #2 (permalink)
JOIN SCOA.YOU'LL BE GLAD
yep....common occurrence with all smarts...also check to see that the area in between the plastic wing nuts are not coming unglued and allow hot engine air to get under the insulation and cargo/cabin area sub floor....
jetfuel
engine compartment cover latch roscoe smart Operation and Maintenance 31 08-12-2010 04:19 PM
Rubberized engine compartment cover Bykrdon smart Operation and Maintenance 11 04-12-2009 08:38 AM
Engine compartment, carpet retainer? NCC1701 smart General Discussion 36 11-23-2008 04:12 PM
Engine compartment cover riversidesmart smart Operation and Maintenance 34 05-27-2008 09:39 PM
Help w/Engine Compartment Cover redbluff smart Operation and Maintenance 7 03-31-2008 04:09 AM
