MDC Cruise Not Working - Smart Car of America Forums : Smart Car Forum
Old 10-12-2009, 01:10 PM   #1 (permalink)
ulflyer's Avatar
Installed it today and it doesn't function. I get a constant blinking green light and the engine light comes on and stays on.
PP14 of the instruction says " After starting the engine the LED flashes until the first push of the brake. The stop light switch is scanned for function. If the stop light switch has an error, the LED flashes continuously and the CC is disabled."
Apparently this is my problem, but there is nothing in the instructions to suggest how to fix this issue.
Everything seems to work as it did before; lights, normal shifting, etc. Have checked the wiring connections; they are plugged in and seems ok. Switch in the control module box is ON. I'm stumped.
Smartmadness is not open today so will try to call them tomorrow.
Meanwhile, if any of you have any suggestions, please let me know by email as I'll get it quicker: clem@ptmc.net
ulflyer is offline   Reply With Quote
Old 10-12-2009, 01:16 PM   #2 (permalink)
Happy Columbus Day!
Old 10-12-2009, 01:33 PM   #3 (permalink)
davreich's Avatar
Hi,
Try the top of page 16. It looks like you didn't disconnect the battery before you started or the connector was still touching. Hope this helps. Dave - Wisconsin
davreich is offline   Reply With Quote
Old 10-12-2009, 03:39 PM   #4 (permalink)
ulflyer's Avatar
Davriech: I did disconnect the batt........but upon re-reading the instructions it said "NEGATIVE lead" ....not the hot wire which I took off! Will just have to un-install the dang thing; man, thats a lot of work to undo! Will start all over in the morn.
Thanks, you've pointed me to the probable cause.
Would unplugging from foot pedal and wiper arm be sufficient to clear the unit?
Old 10-12-2009, 04:12 PM   #5 (permalink)
Which lead you undid should make no difference whatsoever. It's probably something else.
Old 10-12-2009, 05:39 PM   #6 (permalink)
ulflyer's Avatar
Will give Smartmadness a call tmr.
low beams not working ??? charlie brown smart Operation and Maintenance 14 10-11-2009 06:44 AM
DDE stopped working! sherron smart General Discussion 7 04-10-2009 06:29 PM
Ac Not Working JUNOECAR smart Operation and Maintenance 18 04-23-2008 03:33 PM
Something I've been working on ASmartMan Original (450) smart fortwo 2 02-26-2008 09:37 AM
