My smart keeps killing my iPod - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 11-15-2008, 09:23 AM   #11 (permalink)
Smart Enuf's Avatar
Originally Posted by Westfield 11 View Post
I have to pull it out, wiggle it around and even then 1/2 the time I can't get it to work.
So you're saying the socket itself provides current intermittently? Or are you saying the devices' plugs that you insert into the ACC socket don't fit snugly in the socket and therefore don't get a constant flow of current?
It's my understanding that there are at least two basic sizes for the cigarette lighter socket's inside diameter: 21 mm (used in American cars), and ~22 mm (used in many European cars). See Cigar lighter receptacle - Wikipedia, the free encyclopedia
Note: I normally don't cite to wiki, but in this case its information seems to reflect other sources. E.g., see this Miata service bulletin http://www.miata.net/garage/tsb/sb00-09-007-815R1.pdf
So if it's a matter of your plugs not fitting the socket snugly, you should probably get an adapter, which are available in Walmart, Target, etc., or your local auto shop. Or you may get away with putting an O-ring on each problematic plug that's just big enough to wrap around the plug to make the fit snug.
Old 11-15-2008, 11:01 AM   #12 (permalink)
smark's Avatar
I have Power Jolt SE, for my iphone. Charging is really slow after 30 minutes of driving, if any. Don't know if its the 12 volt outlet or the charger. I think the battery in the iphone is bigger then the Smart cars. The 12 volt acc outlet ???????? Maybe the phone is changing the car!!!!!!!!!
Old 11-15-2008, 02:25 PM   #13 (permalink)
I think that was what the problem was. I went down and bought a new plug and it fights very tightly, now it seems to have a glowing power light whenever the car is on. Now that I see your post, I recall that my DLO ipod holder that I use in my Benz has an adapter and that it works all the time. Dopey Me!!!
Old 11-16-2008, 08:48 PM   #14 (permalink)
saronian's Avatar
There is a problem with the iPhone 3G and most 12 volt to USB/Dock charging adapters. There is a solution from BoxWave which allows full charging for the iPhone 3G with any adapters. This iPhone charging adapter charges my iPgone 3G twice as fast as my older iPod car charger.
IPOD dock for Smart oldbike smart Modifications 33 05-13-2010 07:33 AM
Ipod nano (and other mp3) SiestaSmart Audio & Video 64 08-28-2009 08:06 AM
Using an Ipod with the smart YellowSmartofBoston smart General Discussion 33 11-12-2008 02:41 PM
Ipod playing harleysmom smart General Discussion 5 06-15-2008 09:05 AM
Ipod sound canon1753 smart General Discussion 5 01-27-2008 09:50 PM
