Old 06-30-2009, 10:47 AM   #1 (permalink)
Need coolant help
Does anyone know if the coolant available at my local Mercedes-Benz dealer will work in my smart? The spec sheet for the smart says to use MB325.0 but the stuff at the MB store says it is MB325.1. I've not been able to find anything that says the 325.1 exceeds the 325.0. Any help is appreciated. Thanks.
sksmn14 is offline   Reply With Quote
Old 06-30-2009, 11:34 AM   #2 (permalink)
Padawan's Avatar
Drive: Silver BRABUS Cab "Smoky"
Older containers of the MB "Anticorrosion / Antifreeze Agent" were marked 325.0, while newer bottles were labelled 325.1. The part number did not change.
That being said, you should also be fine using an off-the-shelf coolant that is safe for aluminium engines and is phosphate/silicate-free.
Old 06-30-2009, 05:11 PM   #3 (permalink)
:shrug: I was told to just buy a gallon of Peak 50/50. I haven't used it yet, so I have no idea if it's what I'm supposed to use or not...
Old 06-30-2009, 05:33 PM   #4 (permalink)
Padawan's Avatar
Assuming it is the Long Life or Global LifeTime variety, that should be fine.
Why I'm curious about is why people are having to change their coolant on cars that have only been available in the USA since 2008.
Old 07-01-2009, 08:40 AM   #5 (permalink)
The car has 40,000 miles on it and that is when the book says it should be replaced.
coolant question
Where is that stinking COOLANT drain plug? =) SmartKCar Smart Car Operation and Maintenance 35 06-09-2009 09:48 AM
help (450 coolant) mackinnon Original smart fortwo 6 05-05-2009 08:21 AM
Coolant (alternatives) chieftmc Smart Car Operation and Maintenance 2 03-19-2009 07:35 AM
Coolant levels? JD10367 Smart Car General Discussion 5 12-27-2008 09:24 AM
Oil Temp and Coolant Temp Gauge Install VinceLA Smart Car Modifications 22 07-23-2008 08:00 AM
