Old 08-26-2009, 05:07 PM   #1 (permalink)
BARNEY O's Avatar
Drive: PASSION
Need technical support! (differential in tire diameters)
Can anyone tell me how much differential in tire diameters from front to rear there could be or ratio before it would trigger the ESP system?
Doing the math on the Passion, the difference from front to back is .256" in diameters. On the Brabus the difference is .346"
I'm looking at something a little more aggressive like 1.181"
Fronts 195x50x15 (22.677" dia.)
Rears 225x50x15 (23.858" dia.)
Would appreciate someone's expertise on this issue.
Regard,s Barney O.
Old 08-26-2009, 05:48 PM   #2 (permalink)
To the XCAPEPOD!
rfernatt's Avatar
Drive: smart fortwo
I don't know, but jwight witnessed the results firsthand with a set of snow tires that drove ESP/ABS nuts. He may be able to provide some guidance based on that experience.
I can say that 195/50s all the way around work great on 15x6 rims. And, you can rotate.
Old 08-26-2009, 05:51 PM   #3 (permalink)
All I know is what didn't work; some other folks added a lot of info on how to keep different size combos from setting off the computer. Hopefully they'll chime in here.
Old 08-26-2009, 06:37 PM   #4 (permalink)
BARNEY O's Avatar
Drive: PASSION
Do you recall the snow tire size?
Old 08-26-2009, 09:22 PM   #5 (permalink)
BobDiaz's Avatar
Drive: Honda Motorcycle (most of
Why is there a difference in the tire sizes from front to back?
Does anyone know why?
Bob Diaz
BobDiaz is offline   Reply With Quote
Old 08-27-2009, 03:01 AM   #6 (permalink)
Here's the original thread: New snow tires and Rial rims - big problems! [Solved]
"Stock tire size in front, the rears are 175/65 vs. 175/55 so a little taller."
That was enough to throw the computer off.
Old 08-27-2009, 03:28 AM   #7 (permalink)
I would assume the tire size difference between the front and rear is to compensate for the extra weight of the rear engine, but that would be a guess.
Old 08-27-2009, 05:19 AM   #8 (permalink)
BARNEY O's Avatar
Drive: PASSION
Jwight,
Crunching the figures of the 2 tire sizes you listed there was a diameter difference of 1.378" and it caused problems. This helps somewhat,now I know a 10 % ratio difference appears to be too much.Still wonder about my 1.181" dia. difference? It's under 10% but not much !! Could 10% be the max the computer will allow?
Old 08-27-2009, 10:11 PM   #9 (permalink)
There are two size differences - diameter and width. Since this thread is concerned with diameter you may be referring to that.
The diameter difference is a result of the difference in width. The difference in width required a different aspect ratio to get the rolling diameters as close as possible, but not exactly the same.
As to the reason for different tire widths front and rear - that is done for several reasons. The primary one being to induce under-steer. That topic has been discussed frequently before. Related to that is the fact that the front is lighter and that the front tire need not be spec'd to carry as much weight.
Old 08-27-2009, 10:36 PM   #10 (permalink)
So... what is the difference in diameter between the stock passion front tire and back tire? Or are they essentially the same, except for the width?
High Side is offline   Reply With Quote
US aftermarket support? nader Smart Car Modifications 74 12-15-2008 06:15 PM
Wheel stud and bolt circle diameters oldbike Smart Car Wheels & Tires 4 10-21-2008 11:43 AM
support independents belkin666 smart center Dealerships 10 10-20-2008 06:27 AM
Less than 7% Support SCOA Dunerunner Off-Topic Cafe 39 10-12-2008 10:00 PM
Need Florida Smarties Support kwagar Florida Chapter 18 07-21-2008 08:14 AM
