Originally Posted by jwight
Playing with an SG the last few weeks, had it set to display mpg and throttle position (TPS). Anything above 14 or 15 TPS and you can really see the mpg drop. Also, notice the mpg increase as you coast up to a stop. The longer the coasting period, the higher mpg which helps raise the average. Check some of the hypermiling threads here; the SG will show the "pulse and glide" technique really does help. Good luck!
Yep, I noticed the same thing... watch the GPH or MPG readouts change considerably with just a little bit of foot pressure... it's the same thing for other cars, but in the Smart it's more noticeable because the MPG numbers start out higher.
Yesterday I used the "pulse and glide" from school to work, and third time's the charm... 46.1MPG on a 6 mile city trip - a new record for a single trip on a common route. OK, I should call it "punch it and glide" -- Get up to 50MPH pretty quick, go uphill in 5th gear, then downhill coasting in 5th gear. I don't shift into neutral, because that actually uses as much fuel as idling (~0.2 GPH) where I believe coasting in gear uses zero fuel.
The ScanGauge is critical for getting the most MPGs... I started at 27MPG city and now average 35MPG if I avoid peak traffic. In peak traffic like today I only got 24MPG - but I was also in a downpour of rain, dodging idiots and idling at lights a lot. And I had the defroster (AC compressor) on.
Bruce, it will get better if your driving habits change. If you drive it like you're compensating for something, you'll get the same mileage other cars do. You can double your MPGs while still going as fast as you normally do by going light on the throttle after getting up to cruising speed - think of flying a jet... pilots are all about saving fuel.
