Oil smell & Heat through Handbrake area - Page 2 - Smart Car of America Forums : Smart Car Forum
View Poll Results: Oil smell and Heat through Handbrake area
Yes, No fix yet 1 2.70%
Yes , It has been corrected 1 2.70%
No, Do not have problem 35 94.59%
Multiple Choice Poll. Voters: 37. You may not vote on this poll
Old 10-16-2008, 07:31 PM   #11 (permalink)
Dress up
I was very pleased with the quality of the leather one I got on eBay. Even with shipping, it was about $25 and arrived in under a week:
SMART FOR2 BLACK HANDBRAKE GAITER SPECIAL RED STITCH - eBay (item 250294631750 end time Nov-12-08 07:18:56 PST)
There are other colors too.
(I have no affiliation with the seller.)
Old 10-16-2008, 07:31 PM   #12 (permalink)
Macaw's Avatar
A hand brake boot is not a "fix" it is just hiding the problem. The dealer needs to find the air leak from the engine compartment and fix it! Keep in mind you may also be getting carbon monoxide from the exhaust sucked into the car. This is not normal!
Old 10-17-2008, 08:37 AM   #13 (permalink)
a2jack's Avatar
I agree with Macaw 100%. A boot is not the fix.
JPs link says the problem is an improper seal on the engine cover. Have the dealer check this out.
A2Jack.
Old 10-17-2008, 11:19 AM   #14 (permalink)
Fumes & Heat from handbrake area
Thanks! That was my thoughts, Like putting a bandaid on a broken leg. I have a appointment for next week we will see what happens now that "I" have identified where the fumes are coming from. Two trips and they came up empty.
n5yn5y
n5yn5y is offline   Reply With Quote
Old 10-17-2008, 12:17 PM   #15 (permalink)
It never occurred to me that anyone would take the cosmetic fix of a new boot as a satisfactory resolution of whatever is the cause of the problem. I apologize if anyone thought I was suggesting hiding rather than correcting the problem.
Old 10-17-2008, 12:34 PM   #16 (permalink)
Handbrake Cover
I got my heat problem solved with Brake cover..
from
Page Title
But i did not have an oil issue.
tparmar1 is offline   Reply With Quote
Old 10-17-2008, 01:44 PM   #17 (permalink)
Macaw's Avatar
No apology needed I just come off a little harsh online....The boot looks nice they had them at SCI last time I was over there.
Still on subject there should be no heat/air flow from the area period regardless of smell/no smell.... REMEMBER you car is under warranty take it in and get it fixed (I'm a warranty electronic repair tech) don't wait for the warranty to expire....
Old 10-20-2008, 11:29 PM   #18 (permalink)
saronian's Avatar
Originally Posted by n5yn5y View Post
...When you are driving with windows closed and then put down either one of the windows it appears that it creates a draft through the Handbrake area and if you drive long enough the lower portion of the Handbrake becomes to HOT to touch. Anyone else having this problem. If so Please advise and also if you know of a Fix. Many Thanks!
I did this test on my passion coupe and the handbrake did not become hot, not even slightly warm. No portion of the area where the handbrake passes through the carpet changed temperature or leaked air. This was tested while driving about 60mph for 30 minutes.
So not all fortwo's have the same problem which should be easy for the dealer to test.
Old 04-17-2009, 06:15 AM   #19 (permalink)
Dont Feed The Trolls ^Mod
jediknight36's Avatar
Happens with the windows down too.
Old 04-17-2009, 02:43 PM   #20 (permalink)
saronian's Avatar
That was the test. First with windows up, then one open, then two open. None of the conditions brought hot air to the hand brake area.
Some have said this occurs when the engine cover is not completely in position and tightly closed.
Burning smell eqwalker smart fortwo (451 - US vehicle) 46 02-26-2011 10:18 PM
Aftermarket Handbrake options? akiranakayama Interior & Exterior 11 10-09-2008 09:51 AM
Smell Of Gas goldseekur smart Operation and Maintenance 1 06-14-2008 06:08 AM
I Smell A Rat! uncletony smart General Discussion 10 05-15-2008 03:52 PM
Burning smell when new? brian r smart Operation and Maintenance 5 04-20-2008 10:07 AM
