Originally Posted by jediknight36
OK! There is at lest one place in DFW that will do the hubrik optik tint nd its Pro-Tint!
yes. huper optik is not avail direct to consumers, generally only through very good pro installers. the installer i used here also does the state police cruisers and they do large commercial buildings and such as well.
took about an hour to do the smart - the tint was first pre-cut on a computerized plotter-cutter CAD system so there are no hand-cut trim lines, it's an exact fit size-wise for each window - then they soap up the exterior of all windows, and heat-shrink each piece of ceramic tint to exactly fit the curvature of the glass without wrinkles or overlaps - from what they told me and what i observed, the little bubble window behind the main window on the smart's doors present a challenge for two reasons, one because it is slightly parabolic, requiring careful molding in two axis to get it just right and two because the rubber around the window is completely flush, there is no fudge-factor for fitting it.
once each piece has been heat-molded to the exact curvature of the 5 windows, they are carefully transferred to the inside of the glass, fit carefully and squeegeed out for perfect OEM-looking fit.
initial curing was about 48 hours that i did not roll down the windows or do anything that might alter their placement - after that all was good. full curing takes a few weeks as the ceramic film is significantly thicker than most others and as such, takes much more time to fully dry. they recommend parking it in full sun - the more sun and heat it gets initially, the quicker it will cure. they said it may bubble a bit during curing but that it would go away once fully cured - i never got any bubbles regardless.
their install was also guaranteed so if anything went wrong, they would re-do it at their expense. great quality shop to work with. for those in the MA/New England area, the installer was
tint-king.com/
i paid about $325 for the ceramic (4 side windows and a one-piece rear window)
while i was there they also did an escalade, 2 porsches and a ferrari.
they had the pattern to do the roof window as well, but i opted to leave that as-is.
