Passenger Seat Heat Not Working - Smart Car of America Forums : Smart Car Forum
Old 02-08-2009, 11:19 AM   #1 (permalink)
sheureka's Avatar
Yesterday, for the first time since I got my car last April, I turned the heat on the heat on the passenger seat. The light flashed on for a few seconds and then went off - and there was no heat. The manual says if this happens there's a malfunction and I should take it to the dealer. My dealer is several hundred miles away and would probably mean at least an overnight trip and I'd really like to avoid that if possible. Does anyone have any idea about connections, fuses, wiring, etc., that I could check without taking it in? TIA - sheureka
sheureka is online now   Reply With Quote
Old 02-08-2009, 11:23 AM   #2 (permalink)
HGB
HGB's Avatar
There are several separate connections under each seat. Don't know which is which, but make sure they are all well connected. Flashlight time.
Check fuses too.
Good Luck...
Old 02-08-2009, 12:02 PM   #3 (permalink)
Admin/Mod.
Did you check Evilution's site? See under "Maintenance", "DIY/FAQs" stickie. It's the last link. Good luck, and keep us posted.
Old 02-08-2009, 12:18 PM   #4 (permalink)
Here is Old smart's fuse table
#-Circuit-Amp-Color
22 Low beam headlight, left 7.5A Brown
23 Low beam headlight, right 7.5A Brown
24 Brake lamp, rain/light sensor, combination switch left 15A Blue
25 High beam headlight, left 7.5A Brown
26 High beam headlight, right 7.5A Brown
27 Engine 7.5A Brown
28 Rear window heater (coupé only), engine cooling fan 40A Orange
29 Soft top (cabriolet only) 30A Green
30 Transmission 40A Orange
31 Horn, doors, central locking 20A Yellow
32 - - n/a
33 Ignition 50A Red
34 esp 40A Orange
35 Power steering 30A Green
R1 Mirror heating 5A Lt. brown
R2 Backup fuse (ignition switched +) n/a
R3 Backup fuse (ignition switched +) n/a
R4 Backup fuse (ignition switched +) n/a
R5 Backup fuse (constant +) n/a
R6 Backup fuse (constant +) n/a
R7 Backup fuse (constant +) n/a
R8 Backup fuse (constant +) n/a
R9 Seat heating 20A Yellow
Old 02-08-2009, 12:59 PM   #5 (permalink)
sheureka's Avatar
Since Evilution updated his site, I haven't been able to find anything. Can you give me a direct link? I don't see anything saying "Maintenance", "DIY/FQAs", etc., and searching "heated seat" only tells me how to remove the seat. TIA - sheureka
Old 02-08-2009, 01:54 PM   #6 (permalink)
Admin/Mod.
Same here: couldn't find what you're looking for on Evilution. Even the technical manual available on line is not specific enough to help you.
Seat heaters
The seat heater special equipment in model 451
consists of two heating elements which are installed in
the seat bolster and backrest cushion of each seat.
The seat heaters are activated separately for each
side via the switch panel in the center console.
Pressing the seat heater switch for the driver or
passenger side switches on the seat heater at stage 2.
Another press of the switch switches the seat heater
to stage 1. If the switch is pressed a third time, the
seat heater is switched off. The different stages are
indicated in the relevant switch by the lighting of one
LED for stage 1 and two LEDs for stage 2.
The heated seats control unit incorporates a temper
ature sensor that measures the ambient temperature.
The heating elements in the driver and passenger
seats follow a temperature profile based on this
temperature. The heater output is constantly moni
tored to check the seat temperature.
Function
Function requirements:
• Switch circuit 15 ON
When the seat heater switch for the driver or
passenger seat is pressed, a request signal is sent
directly to the heated seats control unit. In the heated
seats control unit the request for activation of the
seat heater is processed with the function require
ment.
The function requirement is transmitted by the igni
tion/starter switch straight to the SAM control unit,
from where it is forwarded to the heated seats control
unit.
If all the criteria for activation are satisfied, the
appropriate seat heater is switched on by the heated
seats control unit over a direct line.
Remains the Dealership, I suppose, next time you're there for service? Sorry.
Reclining passenger seat dichrodave smart fortwo (451 - US vehicle) 59 07-21-2009 10:14 AM
Help!! Heat not working on SMART 2micro4u smart General Discussion 17 11-23-2008 09:18 PM
Anyone remove the passenger seat? logan74k smart Modifications 5 08-17-2008 05:19 PM
