Originally Posted by Krodista
One thing to consider is the replacement cost for the top every ~5 years~ depending on the weather. You will get extra noise with a soft top and it will only get worse as the top ages. In the end...soft tops are fun...if you can afford it and dont mind the negatives...go for it.
I don't know how the polycarbonate roof will hold up over time, but replacement cost for the clear roof would also need to be factored in to the extent it gets scratched up or cloudy enough to require replacement. I suspect replacing that roof will be as costly or more costly than replacing the fabric top. Plus wear and tear on the cabrio roof can be mitigated to a high degree by using a good quality car cover, which has co-benefits in terms of reducing interior surface fading and reducing air conditioner loading (and by extension, engine wear).
