Pay it Forward_ K&N air filter - Smart Car of America Forums : Smart Car Forum
Old 10-08-2008, 10:48 AM   #1 (permalink)
I replaced my K&N (33-2647) with the BPP one. This K&N is the one most forum members have recommended although it's not made specifically for the Smart. Whoever gets it only pays actual USPS shipping costs. PM me if interested. First come, first served.
Warning: It does have about 1200 miles on it so I'll only be good for another 998,800 miles.
PS When I put it in there was a noticeable improvement in performance.
Old 10-08-2008, 10:51 AM   #2 (permalink)
Good idea; I'll throw mine in as well. A few more miles (approx 1,500) but still as new when it was replaced by the BPP filter. PM me if you'd like it - shipping costs only.
Old 10-08-2008, 11:51 AM   #3 (permalink)
yellow smart's Avatar
What I want to know is, does the K&N or BPP air filter improve gas mileage. That is the only preformance improvement I'm concerned with.
Yellow-Smart
yellow smart is offline   Reply With Quote
Old 10-08-2008, 12:35 PM   #4 (permalink)
SloPok's Avatar
Yellow-Smart
You might see a very very small gain. The filters allow more air into the engine. I have one both of my cars. I put one in a 98 Ranger and really noticed more power and right away.
SloPok is offline   Reply With Quote
Old 10-08-2008, 01:02 PM   #5 (permalink)
Originally Posted by mvaldes View Post
Play it Forward_ K&N air filter
isn't the saying "PAY it forward"?
regardless, it's a nice offer....................
Old 10-08-2008, 01:24 PM   #6 (permalink)
It's highly unlikely that installing a high flow filter will improve power in any road-going vehicle. That statement is based on dyno results from different sources and personal experiences in a number of vehicles including motorcycles. Factory filters are designed to allow air flow commensurate with the needs of an engine. Even removing filters completely does not result in more power. Those who report a power increase are only reacting to expectations which can fool anyone. If you believe strongly enough in a change you will feel it. In some cases there is the possibility of experiencing a little better throttle response which can be deceiving as far as greater power is concerned. The pressure drop due to filters alone is negligible. You need to look to other design factors to increase air flow and power.
High flow filters have the potential of allowing a greater flow but they filter poorly, and effective filtration is the reason for filters in the first place. Filtration shoud be the major concern for any road-going vehicle. Changes in fuel mileage will also be insignificant. To actually benefit from the potential greater flow you need to make other changes as well - like intake path, exhaust systems, valve timing, etc.
Oil impregnated gauze and foam filters have their uses but they are basically relegated to off road competition. I first used them several decades ago in motorcycles for off road competition. For that use they were indespensible since they didn't clog when wet, nor break apart, and they also continued to flow air even when covered with layers of dirt and mud. A paper filter would be disasterous. The situation is reversed for vehicles that travel on public roads, and particularly for those not engaged in competition.
K&N (the company) has done an terrific job in convincing car enthusiasts that their filters will provide benefits. Independent testing has proven otherwise, and indicated that they filter very poorly as well. They do have their uses as mentioned but not for vehicles such as smart cars.
The following references from a reputable source (bobistheoilguy) might be instructive - Air Filter Flow Testing for Napa Gold, Amsoil two stage foam, Jackson Racing foam, Baldwin, Mazda and K&N
Filtration Testing for Amsoil, K&N, Napa, Jackson Racing, Baldwin, and Mazda air filters on a Miata
- and here is another report that might open a few eyes and minds -
ISO 5011 Duramax Air Filter Test Report
I've been through this issue on both other car and motorcycle forums over the past several decades. I don't know if anyone else has raised these points before, but it is sad to see that the smart car 'enthusiasts' are being lured into using these products as well. It's especially astonishing to read that people are wanting to do this thinking they'll get better fuel mileage to no avail and all at the expensive of increased engine wear.
Old 10-08-2008, 01:45 PM   #7 (permalink)
Macaw's Avatar
From personal use of K&N air filters on carburetored motorcycles. Over the stock air box with a good performance exhaust (vance&hines) The entire system flows so much better you had to rejet the carbs a lot. Now this performance increase was usually at the top end and shifted the power/torque curve to the higher end. They absolutly flow more air as seen by the need to rejet but was really only helpful at the top end of the power curve. Now with a fuel injected setup you have to hope that the computer has enough of a range to allow for the higher flow otherwise you're gonna be running lean.
The next question is the stock filter so restritive that it cannot flow enough air from idle to part throttle?
I would think that you would only see a benifit at the upper end of the power band at least that is what I've seen of past vehicle dynoed with a K&N. As for mpg if the benifit is at the top end then you will see no gain in mileage.
I would want to dyno figures on this.
Old 10-08-2008, 01:52 PM   #8 (permalink)
DavidV's Avatar
No - what is sad to see is people still spreading this debunked b.s.
The Spicer report has been thoroughly and soundly discredited. Arlen Spicer returned to K&N's labs for a re-test per ISO standards with him present. When the ISO standards were applied, the results were very, very different.
-- DavidV
DavidV is offline   Reply With Quote
Old 10-08-2008, 02:46 PM   #9 (permalink)
My mechanic calls those K&N type air filters...
Engine Sanders
The Hawk is offline   Reply With Quote
Old 10-08-2008, 03:01 PM   #10 (permalink)
Quagmire's Avatar
Wouldn't it make sence that for a few dollars extra... smart would install these oiled filters at the factory if their benefit was so great?
K&N air filter ASmartMan Dealers and Parts 10 10-08-2009 07:38 AM
$22.00 For An Oil Filter UR2SLOW1 smart Operation and Maintenance 13 04-19-2008 03:01 PM
