Originally Posted by fishrdnc
The ratio with non-P/S is 22:1, and with P/S, 21:1. So what does that mean? It isn't that they put 1/21th more teeth on the rack, or that the pinnion circumference is changed by 1/21th, to make steering easier - that is a stupid thought! But it does argue that there is some difference in the rack end-stops between non-P/S and P/S (probably more robust or cushioned on the P/S to accomodate the additional pinnion torque against them). And as a result, the turning circle of a P/S car will be 1/21th greater than a non-P/S (about 16").
I hate to disagree, but, um, I disagree.
Steering ratio is defined as the ratio between turn of the steering wheel and resulting turn of the road wheel (actually the average turn of the left and right road wheels since the inside wheel typically turns more than the outside). A 21:1 ratio translates to 17.1 degrees of turn at the road wheel for one full turn of the steering wheel. A 22:1 ratio translates to 16.4 degrees. This means that for a given amount of steering wheel lock, a smart with EPS will transcribe a tighter circle than one without (
i.e. the EPS steering is "quicker", if only a little).
Quicker steering can only be achieved by some difference in the steering gear. Changes to the end stops can affect the turning circle, but not the steering ratio. A difference in ratio can be achieve by means other than the number of teeth on the steering pinion (
e.g. shorter steering arms would achieve the same result).
None of this explains why one would bother to engineer such a minor difference into the two systems. That part makes no sense to me...
