Originally Posted by Wizco
Not mine. If the radio is on when the engine is shut off, the radio will be on when I start the car the next time.
If the radio is shut off when the engine is turned off, the radio is off the next time the engine is started.
If however, the radio is turned on while the engine is off, then turned off, the radio will be on the next time the engine is started.
I've seen varying experiences posted about this.
I can tell you for certain . . . My Radio 9 comes on EVERY TIME I START MY CAR, regardless of whether or not it was on when I turned the car off. If did see somewhere on these forums that there is a method of turning the radio on and off when the engine is off, which will make it stay off when the car is turned on. However, it has to be done every time.
So, if yours comes on every time you start your car, your options are limited. Leave it in AUX when you shut off the car, turn down the volume before you turn off the car, or deal with the radio turning on when the car starts.
