Rear License Plate Mount - Smart Car of America Forums : Smart Car Forum
Old 01-19-2008, 01:46 PM   #1 (permalink)
FWOIII's Avatar
Does anyone know the mounting procedure for the rear plate? The two small indentations do not line up for our plates. Is there a rear bracket similar to the one provided for the front and furthermore, if you drill the indentations on the front, what's behind the plastic?
FWOIII is offline   Reply With Quote
Old 01-19-2008, 04:32 PM   #2 (permalink)
smart will provide brackets for both - unless you tell them not to prior to delivery. If you don't like the idea of drilling into your car, use double sided tape to hold the plates on. Works fine, no holes, can be removed easily if needed. Just my .02.
John
Old 01-19-2008, 04:39 PM   #3 (permalink)
Compensating For Nothing
RLove's Avatar
I used several heavy duty magnets for the front tag on my Audi TT. 75lb pull magnets will hold the tag on at any speed. Epoxy the receiving magnets behind the plastic fascia in the front and the others on the bracket.
They can be ordered here: http://www.kjmagnetics.com/categorie...FQUsPAodqxAnGw
Old 01-19-2008, 04:57 PM   #4 (permalink)
gotwavs's Avatar
You can also get those types of magnets all over ebay. Just search for Neodymium.
gotwavs is offline   Reply With Quote
Old 02-01-2008, 03:27 PM   #5 (permalink)
Rear license brackets?
I took delivery of the new car last evening. Local dealer indicates they haven't received any hardware yet, the holes are intended for European plates. This dealer is using adhesive as a temporary fix. Anyone have any updates on this?
riversidesmart is offline   Reply With Quote
Old 02-01-2008, 04:00 PM   #6 (permalink)
My smart came with a front plate mount. Ethan from the Seattle Smart Center informs me that there is no mounting plate for the rear. Yeah, that sounds kinda wierd to me too.
Oliver
Oliver in Seattle is offline   Reply With Quote
Old 02-02-2008, 08:53 PM   #7 (permalink)
Update on the rear plate thing. In order to correctly mount a rear laser shifter (Escort SRX) I needed a regular plate holder with screws top and bottom. At Smart Center Seattle, the mounting solution is to use two steel machine screws to bolt the plate to the rear panel directly. This was not going to work for my purposes as the laser shifter mounts to the bottom of the plate. So I went down to Shucks and picked up a universal mounting plate, which is basically a nylon plate with a bunch of adjustable mounting points to the car. I also picked up a set of nylon screws.
Using a steel machine screw of the same diameter and thread pattern I threaded the inside of the plate mounting holes on the mounting plate. I cut off the nylon screws with a small hack saw.
It turns out the mounting plate fits perfectly in the small indented areas in the rear plate location. So the plate frame is on and I can put the laser shifter in the correct location.
A bunch of trouble to go through. Of those dealers mounting plates with adhesive while waiting for the 'official' mounting plates, is there any word on what that solution will look like?
Thanks
Oliver
Old 02-02-2008, 09:29 PM   #8 (permalink)
Dont Feed The Trolls ^Mod
jediknight36's Avatar
here in texas, they are screwing in a 'dealer' bracket. We require a front one too, but they are not doing that... dunno whats up with that. But for now Im glad.
Old 02-02-2008, 09:33 PM   #9 (permalink)
spdickey's Avatar
My dealer drilled both the front and back plastic to mount the frames. I haven't touched the screws yet. I'll wait until my license plates arrive.
Old 02-03-2008, 06:37 AM   #10 (permalink)
FWOIII's Avatar
smart USA says rear plates are to be attached directly to the rear pannel with 3/4 in stainless self tapping screws. Make your own template. My dealer did that and mine is perfect.
What is your Personalized Plate Going to BE Gene_SD smart General Discussion 713 02-08-2012 05:20 PM
License Plate Wile E. Coyote smart General Discussion 67 08-29-2010 05:34 PM
Front License Plate bracket? FWOIII Interior & Exterior 70 10-14-2008 06:19 PM
The plate came ASmartMan smart General Discussion 23 02-28-2008 04:59 AM
