removing panel to replace horn - Smart Car of America Forums : Smart Car Forum
Old 11-23-2008, 06:35 PM   #1 (permalink)
Can anyone give detailed instructions re removind driver side panels near headlight in order to install new aftermarket horn?
gmarc1947 is offline   Reply With Quote
Old 11-23-2008, 07:18 PM   #2 (permalink)
Supporting Tuner
Evilution's Avatar
__________________
Old 11-23-2008, 10:27 PM   #3 (permalink)
Then there is this also:
Tutorial: Replacing the factory horn
http://www.smartcarofamerica.com/forums/f75/tutorial-replacing-factory-horn-4203/#post43478
Old 11-23-2008, 11:07 PM   #4 (permalink)
mendo's Avatar
I took the Left Front tire off, then loosened the inside fender well by taking out a couple of the plastic rivits and reached in there to change mine, pretty easy.
Old 11-24-2008, 07:26 AM   #5 (permalink)
I'm glad it was for you; I could not get that method to work for me as the fender liner is just too rigid to bend out of the way. Is it possible to remove it entirely? Thanks!
Old 11-24-2008, 06:49 PM   #6 (permalink)
deaconpark's Avatar
John, I was able to perform the mod this way. I did however need a friend of mine to help me out in order to figure out how to mount the horn on the factory mount. I love the horn though and am glad I figured it all out.
Russ
deaconpark is offline   Reply With Quote
Old 11-24-2008, 08:43 PM   #7 (permalink)
gbryers's Avatar
Depending on what horn you get as a replacement (I put in a WOLO BadBoy), you may have to mount it on the back-side of the frame/panel/whatever you want to call it, instead of on the front, as the factory horn is.
I went the route of taking off the rocker-panel cover, then the driver-side of the front, and pulling it out of the way. No big deal, really (though I put the rocker-panel cover on the hard way afterwards), and it doesn't take all that long to do it.
Removing that stupid padding (450) micromachine Modifications and Repairs 11 11-14-2008 07:47 PM
removing the roof pads ASmartMan Modifications and Repairs 11 09-17-2008 04:47 PM
Replace or paint keyed panel? ADA1958 smart Operation and Maintenance 13 04-02-2008 03:46 AM
Removing Safety Stickers Westfield 11 smart General Discussion 5 01-31-2008 04:57 PM
