Reserve indicator inaccuracy? - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 06-01-2008, 10:33 PM   #11 (permalink)
bottlerocket's Avatar
I thought the tank was 8.7 plus 1.3 in reserve...
bottlerocket is offline   Reply With Quote
Old 06-02-2008, 10:28 AM   #12 (permalink)
unicycle's Avatar
What a difference a word makes...
Here is a link with really technical info: http://www.smartusa.com/smart-car-te...fications.aspx
To paraphrase this other page: The fuel tank holds 8.7 gallons INCLUDING 1.3 gallons in reserve. That's INCLUDING ** not PLUS!
Old 06-02-2008, 11:50 AM   #13 (permalink)
smart happens here!
SmartCard's Avatar
Originally Posted by SmartDigger View Post
also the volume of gas changes with temp. gas volume expands as temp goes up
not appreciably...only if "gas" was truely a gas (as in vapor), then its volume would increase with temperature, and marginally at that! For example, 1 "gal" (technically should be in volume) of gas vapor would only increase to 1.06 for a 20 degree increase (ie, 70F to 90F)
Old 06-02-2008, 01:31 PM   #14 (permalink)
Originally Posted by unicycle View Post
Here is a link with really technical info: smart fortwo pure, passion, and passion cabriolet
Got it, glad I didn't take it down farther then!
Old 06-02-2008, 02:54 PM   #15 (permalink)
Dave777's Avatar
Probably a semantically better way to phrase this, to avoid any confusion, would be like this:
The total volume of the tank is 8.7 US Gallons. 1.3 of that is considered Reserve, and the trip odometer switches to a tank countdown mode when 1.0 gallon remains in the tank.
To be honest, they could avoid all this confusion by not ever mentioning the word "reserve." It confuses everyone. It's not a 1959 VW where you can reach up front and flip the lever to get one more gallon when you run out.
Old 06-02-2008, 03:02 PM   #16 (permalink)
smart happens here!
SmartCard's Avatar
I agree...MINI did the same thing - labeling a portion of the tank "reserve". Caused a lot of confusion. Maybe its a European thing?
Old 06-03-2008, 09:48 PM   #17 (permalink)
The saga continues...
Check out my latest fill up: http://www.smartcarofamerica.com/for...html#post85207
Old 06-03-2008, 10:03 PM   #18 (permalink)
Smart Car Geek's Avatar
This is actually a myth confirmed by AAA. The outside air temperature does not effect the gas you are pumping, because the tanks that hold the gas are many feet under ground, where if anything, it is much colder ;)
Also, just a thought, how much gas does the fuel lines hold? Might that be where the 'inaccuracies' stem from?
Old 06-08-2008, 11:30 PM   #19 (permalink)
7.5 g
artificial is offline   Reply With Quote
Old 06-09-2008, 06:39 AM   #20 (permalink)
smarteepants's Avatar
Maybe someone will volunteer to run out of gas and then see how much fuel it takes without topping it off. That might help with all the confusion.
smarteepants is offline   Reply With Quote
SRS Indicator Light SmartCab08 smart General Discussion 47 10-25-2011 06:08 PM
Engine malfunction indicator akuptown1 smart Operation and Maintenance 12 11-19-2010 10:10 PM
If I reserve now - when will I get it (outside of Boston)? katekav North-East Region 16 06-29-2008 10:11 AM
Reserve? Sbrodacz smart General Discussion 14 03-09-2008 10:04 AM
Reserve now! $2500.00 car to be unveiled Carnut The Car Lounge 3 01-08-2008 08:23 AM
