Reserve indicator inaccuracy? - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 06-09-2008, 07:45 AM   #21 (permalink)
In my 40,000 miles of driving the 450 (should be the same size tank), my highest fill (no top off) was 9.2 gallons. May have something to do with the angle of the car on the concrete at the pump.
Ron Gaus, asmartcar.com
rgaus is offline   Reply With Quote
Old 06-09-2008, 12:23 PM   #22 (permalink)
amyrob5's Avatar
I'm really confused.... Got Marta on 5/27 ..... Filled up on 6/1 and it appeared there were about three bars left on the readout . hubby put in 8.24 gallons ....
Today I filled again and there were four bars left and I put in 7.921 ..... seems like the gauge is not accurately measuring the fuel left.
BTW first fill up was about 30 MPG and second was 36.53 I do village to city driving on 15, 25, 35, 45 and 55 mph roads with one stop light, 4 4-way stops and one 2-way stop on an 8 mile drive to work. I guess thats not too bad. I'm going with the BP silver (89) gas as that is what is at the end of my block! The gold is 93.
amyrob5 is offline   Reply With Quote
Old 06-09-2008, 12:45 PM   #23 (permalink)
smart happens here!
SmartCard's Avatar
something is wrong with your display amyrob- with those fillup amounts, you should have NO bars on your gauge! Has the little fuel pump indicator on you display flashed when you got this low; did the reserve countdown come on?
Originally Posted by smarteepants View Post
Maybe someone will volunteer to run out of gas and then see how much fuel it takes without topping it off. That might help with all the confusion.
yeah, your name fits!
Old 06-09-2008, 12:59 PM   #24 (permalink)
MichaelJ's Avatar
Originally Posted by spdickey View Post
The variable here is when the nozzle shuts off. Do not assume that all nozzles will shut off at the same level of gas in your tank. The difference may be one gallon or more.
Also don't assume that any given nozzle will be consistent (although it should be close).
MichaelJ is offline   Reply With Quote
Old 06-09-2008, 01:11 PM   #25 (permalink)
The_Q_Man's Avatar
Originally Posted by SmartDigger View Post
also the volume of gas changes with temp. gas volume expands as temp goes up
Ah, good ol' pivnert. At least that's how we affectionately called P x V = n x R x T.
The_Q_Man is offline   Reply With Quote
Old 06-09-2008, 08:00 PM   #26 (permalink)
amyrob5's Avatar
No Flashing fuel pump and no reserve indicator alerts.... I guess I better pay close attention and figure out where the problem is. Unitil then I better fill up at 1/2 tank!
Thanks!
Old 06-09-2008, 08:09 PM   #27 (permalink)
smart happens here!
SmartCard's Avatar
yes, that's the ideal gas law - its applies to gases only (not to be confused with gasoline!;) )
Old 06-09-2008, 08:17 PM   #28 (permalink)
ShoshTrvls's Avatar
Originally Posted by unicycle View Post
Here is a link with really technical info: smart fortwo pure, passion, and passion cabriolet
To paraphrase this other page: The fuel tank holds 8.7 gallons INCLUDING 1.3 gallons in reserve. That's INCLUDING ** not PLUS!
That's what it says, but I'm betting that someone in Germany needs a vocabulary refresher course. 8.7 + 1.3 very handily equals 10 gallons, a reasonable tank size. And I put just over 8 gallons in mine with 2 bars left. It seems that enough people are reporting being able to fill the car up with 8.5 or more gallons (without running it dry) that I suspect its really a 10 gallon tank.
ShoshTrvls is offline   Reply With Quote
Old 06-09-2008, 09:40 PM   #29 (permalink)
paul c's Avatar
ethnocentric much?
German engineers don't spend their time thinking about US gallons. But 33 liters equals 8.7 US gallons.
paul c is offline   Reply With Quote
Old 06-10-2008, 05:41 AM   #30 (permalink)
I'm beginning to think my gauge is inaccurate and have been filling every 250 miles or so. I recently filled up at the beginning of a trip to PA and the gauge read full until I reached 108 miles, mixed driving.
Tinman2000 is offline   Reply With Quote
SRS Indicator Light SmartCab08 smart General Discussion 47 10-25-2011 06:08 PM
Engine malfunction indicator akuptown1 smart Operation and Maintenance 12 11-19-2010 10:10 PM
If I reserve now - when will I get it (outside of Boston)? katekav North-East Region 16 06-29-2008 10:11 AM
Reserve? Sbrodacz smart General Discussion 14 03-09-2008 10:04 AM
Reserve now! $2500.00 car to be unveiled Carnut The Car Lounge 3 01-08-2008 08:23 AM
