RPM's vs. Speed - Smart Car of America Forums : Smart Car Forum
Old 01-25-2008, 10:06 AM   #1 (permalink)
dbwill's Avatar
RPM's vs. Speed
If soneone has the time could you post the RPM's for 60 and 70 MPH in 5th gear
Old 01-25-2008, 10:12 AM   #2 (permalink)
And maybe for max speed in each gear? Don't know if that's in the owners manual or not. Once we get the info this could be moved to the FAQs.
Old 01-25-2008, 10:28 AM   #3 (permalink)
dbwill's Avatar
Good idea.............
Old 01-25-2008, 10:41 AM   #4 (permalink)
Fred already posted it somewhere here in the forum.
Old 01-25-2008, 11:13 AM   #5 (permalink)
Fredvon4's Avatar
I don't think the list I did had speeds
Gear ratios:
1st (3.308)
2nd (1.913)
3rd (1.258)
4th (0.943)
5th (0.707)
Reverse (3.231)
Final drive (4.529)
I hate the search functions of vb boards and google keeps returning links that I am not logged on for and I get a wanring that I can not see the page due to lack of permissions... argggh!
Old 01-25-2008, 11:25 AM   #6 (permalink)
Gear ratios:
1st (3.308)
2nd (1.913)
3rd (1.258)
4th (0.943)
5th (0.707)
Reverse (3.231)
Final drive (4.529)
It was more than the ratios; it included tire diameter or circumference in the calculations. There was a hyperlink to a calculator in the post. But with just the above ratios and the tire circumference it can be worked out.
Here's one: http://www.car-videos.net/tools/speedrpm.asp
'Nuther: http://wahiduddin.net/calc/calc_speed_rpm.htm
Old 01-25-2008, 11:45 AM   #7 (permalink)
dbwill's Avatar
Fredv your list didn't include speeds. What I was wondering is what rpms I will be turning in various gears, am specifically interested in 60 and 70 as they are the cruising speeds on the freeways around here
Old 01-25-2008, 12:57 PM   #8 (permalink)
24-42's Avatar
Model 450 6th gear 65mph = 2750rpm
Donald LaFavor
Old 01-25-2008, 01:24 PM   #9 (permalink)
Originally Posted by fishrdnc View Post
This one gives 50.6 MPH @ 2500 RPM, 60.7 MPH @ 3000, and 70.9 MPH @ 3500 RPM. You can interpolate between the numbers for 60 and 70. This is for a 451 with 175/55TR-15 rear tires.
Old 01-25-2008, 02:04 PM   #10 (permalink)
Fredvon4's Avatar
Still can't find the post but never mind... the calculator fishrdnc used is virtually the same as the one I used and IIRC about the same results
Don's numbers are with the six speed and I assume stock diameter tires... so within 500rpm of what we are calculating..
some real world posts with the 451s rpm per gear at what speed would help
but for a good ball park the current info is good...
cruising at 70MPG should be in the 3250~3500 range
The brits are reporting that this motor is less buzzy at that rpm then the Gen 2 MCC motor
BTW our versios may or may NOT have the counter ballance shaft **- some versions (Turbo?) are reported to have it...not too sure what the reality is here ...still a lot to learn about this power package
I did find out that a factory fresh replacment motor is $8000 from my parts guy... sounds like buying a PURE is a better deal...hummm I knew a motor would be pricey (was looking into a spare to snuff to preserve the original motor and numbers)
Single Speed/ Fixed Gear Road Bike Rogue Smart Off-Topic Cafe 2 12-06-2007 10:19 PM
conv. top how long to take down/up time at speed sdawg1971 smart General Discussion 3 11-22-2007 07:58 PM
Does the SMART car have speed control? lhoboy smart General Discussion 17 09-17-2007 09:34 AM
