ScanGauge II 4 451 Setup - Smart Car of America Forums : Smart Car Forum
Old 04-29-2008, 12:00 PM   #1 (permalink)
SnakeFarm's Avatar
Anybody have any tips on setting up a Scangauge II on a 451. I set mine to 3ltr enging and 8 gal tank. Then I adjusted the speed up 3 MPH. I also found a pretty close match for the backlight color but I have not set anything else.
What should the closed/open loop setting be?
TIA
SnakeFarm is offline   Reply With Quote
Old 04-29-2008, 12:08 PM   #2 (permalink)
blackbeagle's Avatar
I just got mine last week. You need to change it to 1.0 litre. It's not 3 litre. once you do this, you will get more accurate MPG readings. Mine was off the map. On a highway cruise, I would get 34, 38, 45, 32, 48, 55, and even a few near 100 mpg as I was coasting.
I find that the optimum MPG occurs between 60-65mph.
Old 04-29-2008, 12:10 PM   #3 (permalink)
Open/Closed loop is not a setting. It is the operating state of the computer. It will be "open" until the engine/sensors reach operating temp, at which time it will change to "closed"
Under setup, set it to "1.0 ltr"
Old 04-29-2008, 12:12 PM   #4 (permalink)
SnakeFarm's Avatar
Yeah I really DO have the dumb today. I meant 1 ltr.
It came out of the box set to 3ltr but I changed it to 1 ltr about ten secondes after it woke up.
Old 04-29-2008, 01:01 PM   #5 (permalink)
jthomas119's Avatar
Curent trip mpg gauge
If you haven't already, be sure to create an xGauge for Current Trip MPG. This will allow you to see instantaneous mpg and the mpg for the current trip at the same time.
How to do this is described in the manual. It is fairly easy but somewhat time consuming.
John
jthomas119 is offline   Reply With Quote
Old 04-29-2008, 01:36 PM   #6 (permalink)
randyzimmer's Avatar
re MPH:
my scangauge matches my GPS MPH without adjustment and the speedo is off 3 (reads high).
FYI.
Old 04-29-2008, 02:01 PM   #7 (permalink)
bradgarbus's Avatar
Scangauge and warranty???
Has anyone gotten any negative response from the dealers regarding warranty and using the scanguage or does everyone take them out when you go in for service...
Like a dummy, I asked the service manager for advice and he is emailing the smartUSA to get an official answer for me...
Thoughts?
Old 04-29-2008, 02:08 PM   #8 (permalink)
rgbeath's Avatar
Does anyone know the color settings to match the colors of the gauges.
I have seen it posted before but I can't find it.
rgbeath is offline   Reply With Quote
Old 04-29-2008, 02:32 PM   #9 (permalink)
Dave777's Avatar
Thoughts?
It has no effect on your car. It's just reading information provided by the car's systems.
Old 04-29-2008, 02:35 PM   #10 (permalink)
bradgarbus's Avatar
It does have the ability to "write" back to your cars computer, as well as clear codes...
Not that I would, but...
mpg, scangauge
is it true the ScanGauge II ASmartMan smart General Discussion 33 01-27-2010 09:32 AM
unique Scangauge II install ckigar smart Modifications 31 09-17-2008 10:28 PM
carbon scangauge bracket randyzimmer smart Modifications 9 07-24-2008 05:16 AM
Another DIY Scangauge mount JThw8 smart Modifications 9 04-25-2008 08:55 AM
updated: where does the mpg scangauge look best? mr_Cash smart General Discussion 5 12-02-2007 10:26 PM
