ScanGauge II 4 451 Setup - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 04-29-2008, 02:40 PM   #11 (permalink)
SnakeFarm's Avatar
Originally Posted by rgbeath View Post
Does anyone know the color settings to match the colors of the gauges.
I have seen it posted before but I can't find it.
I think mine is something like Red: 2, Green:1 and Blue:0 but I will check later.
I also have not been able to locate a list of trouble codes on the wonder-net here.
*Not that I in any way expect the smart fortwo will ever have anything like a flaw, fault, blemish, defect, bug, shortcoming, issue, imperfection, deficiency, inadequacy, insufficiency, stain, weakness, drawback or anything that might be called a problem.
SnakeFarm is offline   Reply With Quote
Old 04-29-2008, 03:00 PM   #12 (permalink)
randyzimmer's Avatar
post #49 on scangauge:
"I played with mine last night and found "0 blue" "3 red" and "1 green" to be a pretty close match to full bright smart color."
Old 04-29-2008, 03:10 PM   #13 (permalink)
http://www.evilution.co.uk/index.php...men=Electrical
Old 04-29-2008, 06:27 PM   #14 (permalink)
One more good website with the codes and more.
http://www.fq101.co.uk/tsdatalist.asp
Old 04-29-2008, 06:34 PM   #15 (permalink)
MinnySmart's Avatar
let me know what is found about warranty info regarding the scangauge... I never would have thought it would have been an issue...
MinnySmart is offline   Reply With Quote
Old 04-29-2008, 06:39 PM   #16 (permalink)
Originally Posted by bradgarbus View Post
It does have the ability to "write" back to your cars computer, as well as clear codes...
It can clear codes, but does not have the ability to "write" back to the computer. You can not make any program changes using a ScanGuage
Old 04-29-2008, 06:41 PM   #17 (permalink)
bradgarbus's Avatar
The potential is there for a beginner/reckless user to screw up the computer if they start "sending" commands to the computer... This would be the only reason I can see them saying "no go"
Then on the other hand, what you take out of the car before you go to the dealer won't hurt them... I understand it is just a simple plug, if you mount it with a magnet the dealer would never know it was there...
But then you always have to worry about the tech that can't find an issue, so they blame it on the non-oem device... Even if smartUSA okays it's use...
Its a risk either way, but I think the benefit of owning the scangauge is more important... ( I ordered it yesterday.)
I will still share what I learn from the service manager... He seems be to having a hard time getting an answer from smartUSA. Could be a while if they choose to do some research...
Old 04-29-2008, 06:44 PM   #18 (permalink)
MinnySmart's Avatar
I appreciate the quick response. I'll be sure to take mine out when I go in then. I used a handy 3M Command strip to mount it, and it's holding beautifully... but will pull off with an easy pull of the tab. Just kind of a pain... But hey... only once a year. )
Old 04-29-2008, 06:58 PM   #19 (permalink)
bradgarbus's Avatar
Quoted from the website:
http://www.scangauge.com/features/scantool.shtml
"The ScanGauge II can be used to clear the trouble codes and data which will turn off the warning (Check Engine, Service Engine soon, etc.) lamp."
"» Make and store up to 10 rewritable special codes
to send to the vehicle computer"
For warranty purposes they might have an issue with the customer having this ability....
I DUNNO... Will keep ya posted....
Old 04-29-2008, 07:33 PM   #20 (permalink)
Not Selling on Ebay
red 3, green 1, blue 0 or RGB 310
mpg, scangauge
is it true the ScanGauge II ASmartMan smart General Discussion 33 01-27-2010 09:32 AM
unique Scangauge II install ckigar smart Modifications 31 09-17-2008 10:28 PM
carbon scangauge bracket randyzimmer smart Modifications 9 07-24-2008 05:16 AM
Another DIY Scangauge mount JThw8 smart Modifications 9 04-25-2008 08:55 AM
updated: where does the mpg scangauge look best? mr_Cash smart General Discussion 5 12-02-2007 10:26 PM
