Originally Posted by helidrvr
As long as you follow the calibration instructions in the ScanGauge manual, you'll find the fuel readings to be very accurate.
Today I decided that I had used enough of my tank to do the fillup process. Basically, you fill your tank at the same pump as your initial fillup and record the number of gallons (e.g. 6 g). Then on the scangauge you go to the fillup screen that shows you what it thinks you used (e.g. 5.4). you then adjust the 5.4 value until it shows 6.0. That results in a % adjustment that it saves. In my case, it was 10%.
My assumption is that this 10% (and the related speed adjustment) are used when it calculates the various mpg values.
This 10% adjustment is a pretty big hit so the mileage that we see on the scangauge with default values is much better than it really is.
I would like to hear what adjustment values others get. I did read somewhere that one has to do this adjustment procedure 4 or 5 times to get an accurate value.
John
