Old 06-10-2009, 09:21 PM   #1 (permalink)
Red Roller Skate
fpage77's Avatar
Drive: '09 passion coupe
Scangauge setup?
I get the engine, unit, and fuel screens but am a bit confused. The speed screen is only needed if you have something not factory????????? I'm trying to figure out if out of the box it has to be adjusted. I'm thinking if I understand right with factory tires and hardware the car is sending the speed to the scangauge and you only have to adjust it in case you changed something in car that would cause the speed send to scangauge to be off. I'm getting my unit by UPS on Friday and that's the only setting I'm iffy about. Please any advice about setting up would be welcome.
Old 06-11-2009, 02:15 AM   #2 (permalink)
I didn't have to make any adjustments for the MPH readout. I believe it is the same as what goes to the speedometer.
Old 06-11-2009, 03:05 AM   #3 (permalink)
Wdhitch's Avatar
Drive: 08 smart;00 Town & Country
If you're running stock tires and wheels you don't need to change the mph settings. Do understand that once at highway speeds, your scanguage will not match your speedo... the speedo is not correct over 45mph... The scanguage will show your true speed.
Old 06-11-2009, 01:16 PM   #4 (permalink)
Nicholas / Linda
Nicholas's Avatar
Drive: 2006 Honda Ridgeline
Someone want to tell him the colors to match the dashboard color?
Old 06-12-2009, 12:05 PM   #5 (permalink)
Red Roller Skate
fpage77's Avatar
I got it hooked up in place I want it in the car. Please see below the settings I have put in and tell me if anything needs to be changed. (I know some of what I'm typing in self explanatory but I like being thoorugh)
ENGINE
1 Liter
SPEED
0
FUEL
Type: Gas
Tank size: 8 Gallon (should I select 9 since car has 8.72 gallon tank????)
Cutoff: 24 (this is default value and I don't know if it needs changing for smart????????)
UNITS
Miles
Fahrenheit
Gallons
PSI
I would like to know what LED color combination I need in order the match the smarts orange glow. I think the laster poster mentioned someone should tell me.
Old 06-12-2009, 02:55 PM   #6 (permalink)
SubSlr88's Avatar
Drive: 04 Murano 08 Passion Coupe
On your tank size use 8 gallons - that way you'll never run out of fuel.
Not sure what the cutoff is used for - ? Everything else looks ok. Color? I wasn't ever able to get the orange that matched the dash display - just opted for a brilliant green that is readable in daylight.
Old 06-12-2009, 02:59 PM   #7 (permalink)
Wdhitch's Avatar
Don't worry about the cutoff... and yes leave it at 8 gallons on the gas tank
Old 06-12-2009, 03:24 PM   #8 (permalink)
Quoted by Randy Zimmer:
"I played with mine last night and found "0 blue" "3 red" and "1 green" to be a pretty close match to full bright smart color."
MFoster: red 3, green 1, blue 0 or RGB 310
These settings and 9 pages more stuff in this thread:
ScanGauge II 4 451 Setup
Old 06-12-2009, 04:10 PM   #9 (permalink)
Red Roller Skate
fpage77's Avatar
I completely started the setup process again. I've checked my ScanGauge and it has version 3.16 firmware on it (FYI). I cleared my device back to factory defaults. I found in display settings the color section and set the color to that orangish red preset color which is pretty close to the smarts. The settings below are what I am using in my ScanGauge II and I left out the sections I didn't touch that needed no changes.
ENGINE
1 liter
FUEL
Type:
Gas
Tank size:
If the size in the manual is not in whole units, use the next lower value. For instance, if the capacity is 17.5 Gallons, use 17 Gallons. It is better indicate less fuel remaining, than really is.
I set the size of my tank to 8 gallons based of manual recommedations.
Cutoff:
The default is right for most vehicles, but it can be adjusted by pressing the upper left or right button. The setting is not critical, but is best if about 4 above the no-throttle TPS value. If set to "0" it disables this method of fuel cutoff sensing.
I drove my car around and got on some really big hills and let off gas and let her coast down and my TPS value with AC on stayed at 16 and with AC off dropped to 14. I have done as the manual says and I set my cutoff to 18 since my lowest was 14. The PDF manual on manufacturers website doesn't mention the cutoff feature but the paper manual does (finally RTFM).
Old 06-12-2009, 06:27 PM   #10 (permalink)
Green Kermit Kar Owner
Bum-bling-B's Avatar
Did you play with the X-Gauge feature yet? I keep my Tank Average on the main screen (TAV is what I input on my screen)
MPG Air Intake
TAV WT
That's my preferences I run; lately I've traded the MPH for the Air Intake. Your preferences may vary as well as everyone else's.
