Shifting in Reverse problems! or shifting period - Smart Car of America Forums : Smart Car Forum
Old 02-26-2012, 02:37 PM   #1 (permalink)
smartcarballer's Avatar
Has anyone else had problems shifting in reverse and not being able to, unless you tried several times? Does anyone know a fix to this? I have had the free upgraded software to my 2008 Smart ForTwo Passion, and it is still having problems. Not a big deal but would like to know how to permanently fix it.
Thanks,
-SCB
SmartCarBaller
smartcarballer is offline   Reply With Quote
Old 02-26-2012, 02:47 PM   #2 (permalink)
Padawan's Avatar
Which upgrade did you have? There was the "2.0" upgrade that essentially brought the 2008 transmission software up to 2009 spec, and there was also a specific software update intended to resolve issues with the transmission not engaging reverse or drive. From what you're describing, it sounds as though the latter is the one you need.
The Following User Says Thank You to Padawan For This Useful Post:
smartcarballer (02-26-2012)
Old 02-26-2012, 02:50 PM   #3 (permalink)
Old 02-26-2012, 03:23 PM   #4 (permalink)
a2jack's Avatar
SCB After you read this thread you will really feel bad.
Looks like it will be out of your pocket. MB has been refusing to help on anything even slightly out of warranty.
.Worse, they seem to have a competency gap in their Smart service Depts A2Jack
The Following 2 Users Say Thank You to a2jack For This Useful Post:
kennyrayandersen (02-26-2012), smartcarballer (02-26-2012)
Old 02-26-2012, 07:10 PM   #5 (permalink)
Thank you!
A2jack, thank you, for the reply! do you know how much it will cost me? This is crazy! It does not bother me, life has more important things to worry about, but if its not to much to fix I would like it to be permanently fixed.
Also, thank you, Padawan-(1st post), and Jwight-(2nd post)! Your help is appreciated!
GodBless, stay safe in the week ahead while driving Smart !
Thanks,
-SCB
SmartCarBaller
Old 02-26-2012, 07:24 PM   #6 (permalink)
Mad about smarts and Cats
BB Benz's Avatar
This may only be the 2.03 update. Depending on the dealer, it may be done at no charge, as it is only a software update. Or, they may charge for the software update. I've seen it done out of warranty once at no charge. I understand others charge to do it.
I admired the dealer that did it for no charge of course. Good luck. It is a very common known condition. I understand the upgrade is the 2.03 software update. Again good luck.
BB Benz is online now   Reply With Quote
Old 02-26-2012, 07:51 PM   #7 (permalink)
Padawan's Avatar
I can't seem to find the thread, but I recall someone reporting that he/she was charged less than $100 for the update.
Old 02-27-2012, 04:35 AM   #8 (permalink)
To the XCAPEPOD!
rfernatt's Avatar
The "2.03" update cost varies by dealer. I called a few and the price ranged from $95 to $165. I had the update installed on my 2008 in Charlotte and they charged $95 to update the transmission software and any other software the car needed while it was hooked up to the machine (ECU, ABS, etc.). The car came back cleaned and ready to go in about 1.5 hours.
Old 02-27-2012, 06:35 AM   #9 (permalink)
a2jack's Avatar
Sbc. Rfernatt has your answer Post #8. But it depends on the dealer. Ask.
Then please post here what they charge. A2Jack
Old 02-27-2012, 07:57 AM   #10 (permalink)
The original cause of the "not going in reverse" was the hub on the clutch disk would bind/stick on the input shaft of the transmission. It was debatable as to if the hub could be cleaned and re-lubed with a different lube or the disc had to be replaced (my was replaced and re-lubed with different lube). There was a running change to the disc hub material and tolerances at one point also.
SLIVERS is offline   Reply With Quote
The Following 3 Users Say Thank You to SLIVERS For This Useful Post:
a2jack (02-27-2012), chieftmc (02-27-2012), jwight (02-27-2012)
reverse gears, shifting, shifting problems
Shifting dosmil11 New Members Area 15 04-04-2011 06:31 AM
Shifting sfterry smart Operation and Maintenance 2 01-26-2010 12:07 PM
Shifting problems kolby66 New Members Area 1 09-17-2008 11:01 PM
Shifting Shane5500 smart General Discussion 4 09-14-2008 01:20 PM
Shifting ? SmartDigger smart Operation and Maintenance 11 04-21-2008 08:47 AM
