Significant decrease in fuel economy - Smart Car of America Forums : Smart Car Forum
Old 07-31-2010, 07:39 PM   #1 (permalink)
Been smart for 3.59 years
NCC1701's Avatar
Ok, I know it's Summer (believe me I know ). But, I'm wondering if any of you think I might have a problem, and if so, what it could be. Check out these graphics, including my latest fuelups at fuelly.com
Even my overall average at 93 fillups has dropped by 0.4 MPG, after being rock steady on 35.0 for a year. I'm thinking that that much of a drop in a 2 year average might be cause for concern. My July average is almost 5 MPG lower than last August's average.
Old 07-31-2010, 07:44 PM   #2 (permalink)
To the XCAPEPOD!
rfernatt's Avatar
That is odd... No recent changes in your typical driving environment (driving uphill both ways?), the car itself, or your driving habits? The typical possibilities like restricted air filter, restricted exhaust/catalytic converter, mechanical drag (parking brake issues), etc. come to mind.
Old 07-31-2010, 07:50 PM   #3 (permalink)
NCC1701's Avatar
<slaps forehead> Air filter! It likely is overdue for cleaning. Could that alone be the cause? I haven't really noticed any decrease in performance. No more than any other A/C on in the past performance.
Old 07-31-2010, 07:57 PM   #4 (permalink)
To the XCAPEPOD!
rfernatt's Avatar
I wouldn't think an air filter alone would be that dramatic and that sudden. You'd probably have seen it slowly dropping off over time, but it certainly wouldn't hurt to check/change it.
Also, do you typically get gas from the same station? Have you changed stations lately? If not, maybe you should try a different station for a couple tanks.
Still using original spark plugs or have they been changed?
If you can't find anything else to check or try, you could try disconnecting the battery and let the ECU revert back to its stock state and see if it makes a difference.
Old 07-31-2010, 08:03 PM   #5 (permalink)
Owner for 3.8 years
Kermit's Avatar
Same thing has happened to me NCC. Of course I added bigger wheelss/tires too. I could swear the road is stickier due to the asphalt being so hot, that and heavy A/C use could be a factor.
Old 07-31-2010, 08:08 PM   #6 (permalink)
To the XCAPEPOD!
rfernatt's Avatar
Could be... Is it really that much hotter than last year or earlier this summer?
Old 07-31-2010, 08:13 PM   #7 (permalink)
Let's check off the usual stuff:
* have you run the AC a lot lately?
* check your tire pressures
* clean/replace the air filter
* if you hit a big pothole or critter, check the alignment
* could be a batch of bad gas/wrong gas
* pump clicked off early
* are the O2 sensors still plugged in?
bluedeuce is offline   Reply With Quote
Old 07-31-2010, 08:14 PM   #8 (permalink)
Owner for 3.8 years
Kermit's Avatar
I don't know about Panama City, but we cleared 100 today just a few miles up the road. Yes, it is hotter.
Old 07-31-2010, 08:16 PM   #9 (permalink)
NCC1701's Avatar
I've got the Breathless Performance filter. Could need cleaning. Actually, it's never been cleaned since BBB installed it, and I don't know precisely how to do it. I can research it though.
Whenever possible, I go to the same station, and the same pump at that station.
I'm not sure. Isn't a spark plug change part of the 20K scheduled?
Stock state?
Old 07-31-2010, 08:22 PM   #10 (permalink)
NCC1701's Avatar
Yes. But, that's par for the course, most of the year, nothing unusual.
Yes, all correct. Check 'em at least monthly.
Current likely suspect. But, would it amount to a 20% decrease in MPG?
Nope.
Chevron 93. Consistently bad for 90+ days?
Multi-tank averages in discussion
If not, why not? And, how would I know?
Plunging fuel economy? TMACK smart Fuel Economy 46 04-28-2010 09:56 AM
2009 Fuel Economy SmartPassion The Car Lounge 12 09-20-2009 03:35 PM
Fuel Economy of the Smart Car Antoni Scott New Members Area 37 04-19-2009 07:19 PM
Disappointing Fuel Economy Westfield 11 smart General Discussion 67 07-01-2008 10:20 AM
