Like John said, are you using just 'regular' unleaded or a higher octane as required....91 or above?
Second, you say you just got your smart but you don't say if it's new or a used one. Is it an '09 or an '08? If you have an '08 model, you might want to make sure it's had the trans update done to it. That should make it shift somewhat smoother, from what I understand.
Also, are you using the paddles or leaving it in 'auto' mode? With the paddles, if you run your RPM's up too high, you might find it 'nose diving' when you shift. Just all depends on your driving habits and many other factors.
Good luck with your smart!
