Smart Fix-a-Tire thing REALLY works - Page 2 - Smart Car of America Forums : Smart Car Forum
Trailer
Old 03-12-2009, 04:03 AM   #11 (permalink)
Originally Posted by brian r View Post
Call Tire Rack or just order online. They have a warehouse in DE and will drop ship it to your installer.
That's exactly what I did. They have great prices and ship quickly. Worth considering.
mrc59 is offline   Reply With Quote
Old 03-12-2009, 05:54 AM   #12 (permalink)
I had a bolt go through the tread section on the front tire. It was so big that most of the solution just ran out of the hole onto the cold, wet, rain soaked road. and all over the bottom of the pump, etc. I was able to limp at about 5-10 mph for 1/2 mile to a repair shop who plugged the hole and charged me 8 dollars for the job. That was about a week ago, and the tire is holding fine. The dealer apparently knows nothing about tirerack.com. The mechanic saitd these new plugs are used on TRUCK tires, and the repair ougth to be good for probably 3 years, which at my yearly mileage would far outlast the tread on the tire.
Jimbo is offline   Reply With Quote
Old 03-12-2009, 06:35 AM   #13 (permalink)
Here's what I carry:
Buy Now: Stop n Go Tire Repair Kits Motorcycle Flat Tire | Pashnit
Then just use the "compressor" to refill the tire
Old 03-12-2009, 06:54 AM   #14 (permalink)
Ultraseal Pre-Flat Product Alternative
Mentioned this in other threads before... the Ultraseal PRE-flat alternative sealant is a viable solution. We are up to 10,000 miles on our testing this product inside the wheels of our 2008 smart. No malfunctions, no false readings, no air loss. Seals the punctures (up to 1/4") immediately upon incident. As far as we know, we are the only ones to have tested any Pre-flat sealant product in tires with Tire Pressure Sensors. Ultraseal has worked flawlessly for us. We do sell this stuff, so take our objectivity with a grain of salt if you wish, but we also love the product for what it does for our peace of mind.
Ron Gaus, aSmartCar.com, St. Louis
rgaus is offline   Reply With Quote
Old 03-12-2009, 08:00 AM   #15 (permalink)
jose3030's Avatar
Just called my dealer. The liquid itself is $44.. Seems excessive but that's what they recommend for the smart. I'm going in for a new tire, 10k service and inspection on Saturday
jose3030 is offline   Reply With Quote
Old 03-12-2009, 08:02 AM   #16 (permalink)
jose3030's Avatar
Originally Posted by JPaul View Post
Owner's Manual, page 265:
It's a one time use for both, the canister and the tire... The sensor and the rim probably require a thorough cleaning...
I'm going to have them go over it really well, hopefully they do a good job.
Old 03-12-2009, 08:31 AM   #17 (permalink)
SylenThunder's Avatar
Originally Posted by vpkb1998 View Post
Those fix a flat things are bad for your rim, they actually eat into the wheel. This was my experience.
Yes, i will cause the aluminum to oxidize. That is why you have to have it removed as soon as possible. Many people do not realise that Fix-a-flat is only to get you from where you are to the tire shop. I should not be in the tire for more than a day or so. Any longer will not only damage the wehhl, but also will eat away the inside coatings of the tire itself. Some products are better than others and don't do it as bad, but it is still only a temporary, limp-home, fix. I always watch to make sure the hose the wheel, and the inside of the tire out good whenever I have to use the stuff.
Old 03-12-2009, 08:39 AM   #18 (permalink)
hsterk's Avatar
How does the Fix-A-Flat affect the TPMS (Tire Pressure Monitoring System) - Won't it gum it up?
hsterk is offline   Reply With Quote
Old 03-12-2009, 08:47 AM   #19 (permalink)
jose3030's Avatar
Exactly. Perfectly said.
Old 03-12-2009, 11:26 AM   #20 (permalink)
Use water based product where possible
Regarding the tire sealants, use one that is water based (if you can find them). Those will not corrode the rim or cause any other chemical related problem (Ultraseal is water based), while still doing the job required.
How the smart Works Neonspinnazz smart Videos 4 01-29-2009 02:50 PM
How Smart Works Off "How Stuff Works" Site p1nball smart General Discussion 4 09-13-2008 10:05 AM
WORKS Engine program for Smart? lowndex smart Modifications 0 07-01-2008 06:17 PM
What will be the first thing you do with your Smart? SMART smart General Discussion 39 02-25-2008 08:57 AM
How the smart car works spdickey smart General Discussion 1 11-05-2007 12:30 PM
