Smart Key In The Washing Machine - Smart Car of America Forums : Smart Car Forum
Old 10-25-2009, 07:26 PM   #1 (permalink)
gryphon's Avatar
After a sweaty clean-up on the smart I threw my shorts in the washing machine along with another load that had been waiting to be washed. At the end of the wash cycle I started to transfer the clothes into the dryer and found to my horror that I had left my smart's key in the pocket of my shorts and had run it through the entire wash cycle. Aaaaaargh I've read enough on the various forums to know that losing or damaging your key can turn out to be a really expensive proposition, so I wasn't looking forward to the probability of a dead key.
My intent was to open up the key housing before trying it and dry out the all of the water and check the battery. Opening the key housing is really easy, just needing a wide-bladed screwdriver or coin in the fob attachment loop. The battery will pop right out, no tools required. The battery is a CR2016 3 volt lithium cell and should be available from any Radio Shack or equivalent battery supplier. The needed battery type and installation polarity is marked right in the key case.
Much to my surprise, I found no water in the housing...not a drop There is a circular rubber seal that runs around the perimeter of the case and separately, the button bumps are all part of one large piece of flexible silicone. When the housing is assembled the button pad and the case seal are pushed against each other and an excellent seal is made. I checked the battery while it was out and found it reading slightly above 3 volts, this after 16 months of smart ownership (smart normally replaces your batteries at the 20,000 mile service). In any case, after re-assembly, everything worked just fine and I breathed a large sigh of relief that my stupidity hadn't proved costly. Thought you might like to know that the smart key is actually quite secure relative to moisture
This experiment was conducted by a professionally stupid owner...Don't try this at home
gryphon is offline   Reply With Quote
Old 10-25-2009, 07:52 PM   #2 (permalink)
Been smart for 3.59 years
NCC1701's Avatar
Thanks so much for letting everyone know about this! I was caught in a thunderstorm a while back and was very protective of my key, not knowing how water resistant is was. Nice to know the answer is, very water resistant!
Old 10-25-2009, 07:55 PM   #3 (permalink)
Brabus007's Avatar
Thanks... That was a great Smart Key Report...
Old 10-25-2009, 08:06 PM   #4 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...now you need to start a new thread..."who has the cleanest key"...
jetfuel...thanks for the heads up...
Old 10-25-2009, 08:42 PM   #5 (permalink)
SmartDigger's Avatar
You must have a smart washer.
Old 10-25-2009, 08:48 PM   #6 (permalink)
Gilbert's's Avatar
Maybe water is gone after the cycle done sooooo thanks to the washing machine....
Old 10-25-2009, 09:11 PM   #7 (permalink)
h20m0f0's Avatar
My key is looking a little dirty should I use the normal cycle or delicate? and should I use warm or cold water? Better use cold I don't want anything to shrink...
h20m0f0 is offline   Reply With Quote
Old 10-25-2009, 09:16 PM   #8 (permalink)
Independent research
Thanks for conducting the test, for your description of the innards and the attendant reassurance of water proofness. Who's taking their's SCUBA diving for phase 2 of the testing??
Old 10-25-2009, 09:20 PM   #9 (permalink)
For sale pm for details
Turbo42's Avatar
the outcome is not so good if u drop it in saltwater for a minute though
Old 10-25-2009, 09:30 PM   #10 (permalink)
h20m0f0's Avatar
Electronics hate saltwater
Washing a Smart chobocobo New Members Area 12 09-02-2009 02:44 PM
Get a Smart Car out of a vending machine spdickey smart General Discussion 10 08-13-2009 02:22 PM
Whew! Smart Washing Red_Zippy smart General Discussion 26 05-14-2009 04:00 PM
Pampering Your Smart - Washing saronian smart Operation and Maintenance 34 09-09-2008 10:13 AM
Washing the Smart tee4 Mid-West Region 4 02-11-2008 09:34 AM
