Originally Posted by jimvw57
So does this give you a clean start??
Wouldn't Putting it in coarse salt be the same as a salt water bath??
I have heard uncooked instant rice will work too.
If you don't drain out what water you can, yes, you can turn the salt into a salt bath, and that won't help. Ideally if you have access to the silica gel dessicants, you can do a proper job, but these are home remedies.
Have you noticed restaurants with rice in their salt shakers? The salt will absorb moisture and clump, so they use the raw rice to keep the salt free flowing. So, I guess that makes raw rice the dessicant's dessicant.
