Smart piggy back on RV pic - Smart Car of America Forums : Smart Car Forum
Old 10-14-2009, 03:08 PM   #1 (permalink)
This is my RV with a custom Smart carrier I made. My hitch is rated at 40,000 #s towed and 5,000#'s tongue weight. I installed a dump switch for the air bags which makes loading easier. A pair of 2500 # ramps are stowed underneath. So far I have 40 miles on this setup and this weekend I'm going to get about 10 hrs more drive time. The added weight on the rear really smoothed out the ride taking some of the weight off the front axle. Believe it or not the braking is better too. Before under heavy braking the ABS would kick in on the rear and now it just gets traction and stops fast.
Okiesmrt is offline   Reply With Quote
Old 10-14-2009, 03:22 PM   #2 (permalink)
Nice
I have only seen that done with 450's before
Does it stick out at all?
Old 10-14-2009, 03:36 PM   #3 (permalink)
Originally Posted by forestacademy View Post
Nice
Just a couple inches on each side. It's still more narrow than the awnings, door grab handle etc.
Old 10-14-2009, 04:03 PM   #4 (permalink)
What is the change in effective loading of the pusher axle? I'm thinkin without a tag yer definitely taking a bunch of weight off the steering axle..... That long distance between the center of balance on the Smart and the rotational center of the pusher axle means the EFFECTIVE loading is MUCH higher than the weight of the Smart of course....
Still, if within the rated capacities of your frame and chassis elements like wheels and tires then it's good to have choices. I think the only LEGAL limit is that ya not exceed 20,000lb on any single axle no matter how many wheels it has. The load rating of a given wheel or tire is varied by size and type. It all depends, as they say....
I pondered this type setup for our tag-axle DP which has PLENTY of rear capacity on those axles..... but decided to tow instead. The Smart tows pretty well and leaves room on the rear of the coach for a motorcycle lift. On the other hand.... I can't very well BACK UP !
Old 10-14-2009, 04:26 PM   #5 (permalink)
Keep in mind my axles are semi-truck axles not typical RV axles. I have a 200 gallon water tank under the bed in the far rear. It's there just to help take weight off the front axle. The 14 liter engine is quite heavy, especially when compared to a typical RV engine. My CAT generator is up front too...just aft of the 200 gallons of fuel. Trust me the front is HEAVY!
Old 10-15-2009, 07:27 AM   #6 (permalink)
I added another, better pic.
Old 10-15-2009, 07:48 AM   #7 (permalink)
That's an expensive (but totally cool) way to carry a spare gas can.
Old 10-15-2009, 08:15 AM   #8 (permalink)
Owner for 3.8 years
Kermit's Avatar
Looks good Okie.
Old 10-15-2009, 08:21 AM   #9 (permalink)
For piece of mind, I think I'd run it over some Cat Scales the next time you're at a truck stop. Get a reading with the Smart on, and one with the Smart off.
That is the only way you're truly going to know you load situation.
(actually any RV owner should do this, but that's a different subject).
TboneMan is offline   Reply With Quote
Old 10-15-2009, 08:22 AM   #10 (permalink)
DoraAnderson's Avatar
I'm waiting for my daughter to reply to my email, but I think she may have seen this setup on the road recently. She had posted on her facebook page "Haha!! I just saw the funniest thing!!! Huge van, like the ones with the ac built in the back, pulling a smart car!!"
DoraAnderson is offline   Reply With Quote
I got my smashed up little smart BACK today! sixcrows smart General Discussion 13 05-02-2009 06:24 PM
Got my smart back after accident. headless smart General Discussion 18 02-07-2009 08:38 PM
I'M BACK!!! (new home + Smart garage) Neonspinnazz smart General Discussion 11 11-11-2008 09:18 PM
Give back my smart? ritchaso smart General Discussion 6 05-31-2008 03:08 PM
3 days - smart wants it back for inspection BandSofC smart News & Rumors 40 02-02-2008 06:45 PM
