stereo wont work (450) - Smart Car of America Forums : Smart Car Forum
Old 11-05-2009, 11:51 AM   #1 (permalink)
hey ive got a problem with the factory stereo and now it wont work , all i did was disconnect the battery to remove the abs light on the dash and now the radio wont work , does anyone know if there,s a code to reset it cuz when i turn it on it reads safe so i dont know how to get it workin again ....help will be apriciated...,,,thanks..randy
randygt is offline   Reply With Quote
Old 11-05-2009, 01:04 PM   #2 (permalink)
Admin/Mod.
Indeed, to disconnected the battery without following the proper procedure will result in a locked radio. Your separate radio Owner's Manual should guide you to unlock it and the Dealer should have given your (or the original owner) the code...
Good luck!
Old 11-05-2009, 01:40 PM   #3 (permalink)
The Radio9 and Radio10 units in the 451 aren't secured like that.
I sold several Radio10s to various folks on SCOA and never had an issue.
Is your radio an aftermarket radio? Is your smart a 450?
Old 11-05-2009, 03:19 PM   #4 (permalink)
Admin/Mod.
Good luck!
Correction: after checking both manuals I couldn't find any mention of an auto-locking procedure. Sorry.
The above was for the 451. As stated below, the 450 will auto-lock.
Old 11-05-2009, 03:45 PM   #5 (permalink)
This link is to a page on Evilution. It's titled Grundig, so I'm not certain that it pertains to your situation, but the symptoms sound similar:
Good luck and keep us posted.
Old 11-06-2009, 10:10 AM   #6 (permalink)
my car,s a 2005 with a factory cd player am/fm radio
Old 11-07-2009, 10:36 AM   #7 (permalink)
Yes, the 450s radio will lock and the specific code is required to get it to work again. Check the paperwork that you received when you bought the car new.
Old 11-20-2009, 03:59 AM   #8 (permalink)
i never got it new i got it used from a private sale...
Old 11-20-2009, 08:49 AM   #9 (permalink)
lebikerboy's Avatar
You can get a code from a MB dealer but it will cost you...
If you know the original dealer they should have it on record.
Have a look through they owner's manual and associated bit of
paper in the plastic folder you should have received with the car.
It may be in there
Old 11-20-2009, 09:55 AM   #10 (permalink)
If, when the battery is getting old and tired and you want to replace it, would it be OK to feed 12V to the terminals from another battery or a battery charger before disconnecting the almost dead battery and installing a new one? (450 only)
Convertible top wont go up??? artistalana smart Operation and Maintenance 10 05-14-2011 12:18 AM
AC won't work? rayman1946 Original (450) smart fortwo 14 09-22-2009 11:19 AM
Smart wont start security code issue fastsmartcar smart Operation and Maintenance 11 09-17-2009 07:31 PM
smart wont start fastsmartcar smart General Discussion 3 04-27-2009 06:53 PM
What can be done for a stereo/sub(s)? CapWKidd New Members Area 4 11-10-2008 02:55 PM
