Stuck emergency brake...help!! - Smart Car of America Forums : Smart Car Forum
Old 03-09-2010, 07:48 AM   #1 (permalink)
So my 08 Smart For Two has been parked here in Germany for about 5 days. Today I get in and the emergency brake won't disengage. Starts fine but it won't budge from the garage. This ever happen to anyone? Never had a problem with the car. It's been cold here but I don't think it's a temperature issue.
Bucky is offline   Reply With Quote
Old 03-09-2010, 07:58 AM   #2 (permalink)
Admin/Mod.
'Bucky',
Our US version has a slightly different gear shift (P-R-N-D), with a lock on P.
Did you try to push the car to "free" the peg that locks in in "P"?
Or it may be so different that someone from outside the US can give you some hint...
Old 03-09-2010, 08:23 AM   #3 (permalink)
wrumbarger's Avatar
Try pulling UP on the brake handle while pushing in the release button?
Had this happen a couple of times to me.
Appears to be from the car rolling (just a fraction) after applying the e-brake?
Try pulling UP on the brake handle while pushing IN the release button?
This has worked on my US 451 the last 2 times.
Old 03-09-2010, 08:44 AM   #4 (permalink)
Will try it tonight when I get home. Thanks.
Old 03-09-2010, 08:48 AM   #5 (permalink)
It's a European version. There is no "park" mode. You just park it with the gear in reverse and apply the brake. It's definately the brake. I'll mess with it some more tonight.
Old 03-09-2010, 09:29 AM   #6 (permalink)
Drive: Pulse
Happened to me twice on my 450. The metallic particles in the pads rust onto the drums in high humidity. Try clanging the drums with a board and then get in and give it a few jolts of back-and-forth. The brakes will release suddenly with a big old slam.
Old 03-09-2010, 10:53 AM   #7 (permalink)
I don't have a smart yet, but FWIW this happens on my pickup truck in the winter.
PDX-PLT is offline   Reply With Quote
Old 03-09-2010, 11:23 AM   #8 (permalink)
Your brake shoes may be frozen to the brake drums. If the car is in the garage, get some heat in there. If it is outside, try rocking the vehicle or find a way to warm the brake drums to above freezing.
Old 03-09-2010, 01:05 PM   #9 (permalink)
I think Sunny and Gringo are right. It's in a car port actually, and we've had heavy wet snow and freezing temps. I'll try the good old fashion brake drum clanging. thanks for the input guys.
Old 03-09-2010, 01:36 PM   #10 (permalink)
When all else fails; get a bigger hammer
chieftmc is online now   Reply With Quote
Emergency Brake Cover -New web site. rocha113 Interior & Exterior 11 05-15-2009 08:21 AM
BRABUS Emergency Brake Handle w/ Leather Boot smartRRparts Interior & Exterior Styling 0 03-20-2009 04:31 PM
Emergency Brake Failure kitttie smart General Discussion 31 08-27-2008 06:56 AM
emergency brake problem toysmart smart Operation and Maintenance 0 04-26-2008 05:37 PM
emergency brake evilbean42 smart Operation and Maintenance 6 02-11-2008 10:01 AM
